bog at mid throttle
Old May 4, 2017 | 12:35 PM
78Fords's Avatar
78Fords
Angry bog at mid throttle
i have a 78 f100 costom with a 300 i6 1bbl carb. it starts good then when i drive it i will have a loss of power apon acceleration and a bog at mid throttle. i have a vac. gauge and ive adjusted it. it idles smooth at 400 rpms and the engine is in great condition just dont know why it has the bog at mid throttle. anyone have a suggestion?
Old May 4, 2017 | 12:40 PM
D-rat's Avatar
D-rat
Fuel delivery and vacuum. MAke sure you have adequate fuel pressure, and look for vacuum leaks. Is your vac advance on the distributor working as it should?
Old May 4, 2017 | 05:10 PM
Filthy Beast's Avatar
Filthy Beast
I think 400 RPM idle is low for the I6...could cause premature berrin wear/failure. Can you get it up to ~ 550 -600 RPM at idle with no problem? Presupposin' you have a stick and not an auto trans.
Agree on checking for vacuum leaks and checking your vacuum advance can. The carb's base is solid with the rest of the carb and intake, yes?
Old May 4, 2017 | 06:38 PM
78Fords's Avatar
78Fords
vac. advance is working. fuel pump is working ok. probley need a new one. no vac. leaks and intake is good. its an automatic too. i idle it low because thats what it originally did. when i bought it it was idling at around 1200 and never ran right. it always bogged down though.
Old May 4, 2017 | 07:09 PM
Filthy Beast
One thing comes to mind....well, two things. Involves the distributor. Timing set ok?
And how about hairline cracks in the cap....or moisture getting in and around the 6 terminals as well as the rotor button. Any signs of arcing over?
Old May 12, 2017 | 11:32 AM
78Fords's Avatar
78Fords
i have never checked the timing but it has never pinged or had any issues but that is a possibility
Old May 12, 2017 | 01:55 PM
meangreen92's Avatar
meangreen92
Choke set up properly, with the wire to the choke-spring heater connected?
Old May 15, 2017 | 12:27 PM
78Fords's Avatar
78Fords
yes and its a new choke spring and hooked up to the correct wire
MeanGreen72
Jun 16, 2019 11:31 AM
wyckedcombo17
Aug 15, 2014 06:25 AM
59pan
Aug 20, 2007 06:14 PM
Finnford
Jul 8, 2003 05:57 AM
inliner
May 25, 2003 03:21 AM
