Manifold to pipe connection
Old May 2, 2017 | 09:48 PM
PlumCrazy7's Avatar
PlumCrazy7
Gents, I have an exhaust leak where the pipe connects to the manifold. Specifically the flared area where the pipe mates to the manifold cracked all the way around. My issue is that I have no idea what the piece is called or if it can be bought separately from the pipe. Is it just pipe that's been flared? Any info is appreciated.
Old May 2, 2017 | 10:01 PM
Macrobb's Avatar
Macrobb
It's basically pipe that's been flared.
I know Justin @ R&D idi performance has the tool to make these flares; most exhaust shops do /not/.
I'd call him up and see if he'll sell you a short piece with the flare, which you can then weld in place(or have a local exhaust shop do it).
You might also look for a 'ball flare'; I forget what size it was(measure it?) but I got a piece off Summit that worked. Only problem was that that metal was pretty thin and ended up cracking out. Justin uses much stronger steel pipe for his stuff.
Old May 3, 2017 | 11:06 AM
IDIoit's Avatar
IDIoit
FYI, 460's use the same flange.
may wanna try a junkyard?
kabcpapc
1997 - 2003 F150
May 18, 2019 10:34 AM
bigcrunch
Feb 7, 2018 06:02 PM
Bozworth
Apr 9, 2012 11:43 PM
1994F2507.3L
27
Apr 29, 2010 03:16 PM
Tedybear
Mar 24, 2008 10:17 PM
