1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
HELP!!! 2012 F250 Rattle Noise
Old 05-02-2017, 07:20 PM
ZackYoung's Avatar
ZackYoung
ZackYoung is offline
So I drive a 2012 F250 6.2L and recently I've been hearing this rattling noise, kinda like a bag of washers being tossed about. I thought it was the snap brackets for the fog lights cause I removed my fogs and the brackets were loose enough to jingle so I zip tied them and it seemed like the rattle stopped however coming home the other day I hit a pothole and the rattle jingle noise happened again. I've checked most of the front end making sure all is tight which it is so I'd love if someone could shoot me some advice!
Update: There were some lose snap bolts and brackets I'd missed so I took them off but no luck. I have come to the conclusion however the noise only occurs when the suspension is compressed. I figured this out by having my 300lb friend stand on the bumper and then I hit the coils with a mallet and I could hear the rattling noise and no I was not mistaking the coil vibration for the rattle noise.
Old 05-02-2017, 07:52 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Check your step bars if you have them. Why did you remove your fog lights?
Old 05-02-2017, 08:02 PM
ZackYoung's Avatar
ZackYoung
I'll go check them now, I replaced my fogs with Rigid LED lights and then took them off to put on my ATV. I'm gonna buy the SAE rigid fog lights that are street legal.
Old 05-03-2017, 05:19 AM
seville009's Avatar
seville009
seville009 is offline
Check your shock bolts - just grab the shock and wiggle it; it shouldn't move
Old 05-03-2017, 06:27 PM
ZackYoung's Avatar
ZackYoung
Shocks are tight.
Old 05-03-2017, 08:11 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is online now
Pea gravel in hub caps?
Old 05-25-2017, 06:15 AM
ZackYoung's Avatar
ZackYoung
Figured out it's my front bumper, its rattling because I have my fog brackets off right now which also support the bumper.
kmelrose
41
08-22-2017 08:20 AM
Cuzimmattygraz
2004 - 2008 F150
10-11-2010 12:52 PM
Waldonian
2004 - 2008 F150
12-02-2004 02:04 AM
lariatf150
2004 - 2008 F150
06-04-2004 04:40 PM
Quick Reply: HELP!!! 2012 F250 Rattle Noise
