I recently drove the truck home from where I bought it which was about 150 mi. The truck drove great. I parked it an now it won't start as far as I know the batteries are good an I feel the gp wires warm up an my motorcraft gps are good an it has about 10 gallons in the tank does anyone have an idea of what the problem is? I have a feeling it's either bad battery connection or fuel isn't flowing
What's it doing? Is it turning over? Is it turning over SLOW? As far as fuel, have a buddy crank it and push in the Schrader valve on the filter and see if fuel comes out.
it doesn't sound as fast as it should be but I'm charging up the batteries now so I'll see what it does. I know it takes a lot of *** to start these trucks up so fingers crossed hopefully she starts
Get some good charged batteries on it, if it still "doesn't sound as fast as it should" then you probably need a new starter. I couldn't believe the difference in mine. Night and day. Mine was taking several cranks and with the new starter it was almost instant.
You won't enjoy changing it if you have to. These boys are HEAVY.
Just make sure you check and clean all your connections and grounds before spending the money on a starter.
im checking for fuel an I'm about to check the fuel pump I replaced filter (was nasty) an not getting much fuel when bleeding at injection nozzle nor nothing from shrader valve getting power to injection pump an hear it click on
the factory it's not electrical for sure an yes I filled it with diesel
Yeah it could be the pump. If there's no leaks these can still run with a bad lift pump. The injection pump can suck enough to run, but I doubt it would if it sucked air. Let me know what you find when you get to look at the pump.
How much fuel is in the tanks? Sometimes the pickup breaks off and you can't get fuel below 1/4 tank.
Edit: Nevermind you said just over 1/2 tank, my mistake.
