Someone help me with the math....MPG Thread
Old May 2, 2017 | 11:03 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
I know we all try to figure out how to get better mileage. It is a daily struggle for many of us, others have accepted the fact that your MPG will never be great; and others, like Tom, go out and buy something that gets 50mpg for a nice blended average....
A while back I started filling the tank at different levels of empty each time to see if there was any difference. I have noticed that I get better fuel mileage when I drain an entire tank vs when I fill at the halfway point.
I will not bore you with all the details but the averages are this:
Full to Empty - Average 16.8mpg
Full to 1/2 - Average 16.1mpg
So if I am getting .7mpg better when draining the tank 100% vs only 50% can one assume that I am getting 1.4mpg better on the second half of the tank? The only variable that is really changing is weight. Because this was done over several months, factors like where I got the diesel and the temperature would not make a huge difference on the overall average. On times during towing, I would not record that data from those fill-ups since I figured it would mess with the numbers too much.
What are y'alls thoughts?
Old May 2, 2017 | 11:27 AM
Tedster9's Avatar
Tedster9
When dealing with tenths it's necessary to be making accurate comparisons. Refuel at the same location, same fuel type, from the same pump, make sure the tank is topped off exactly the same level every time, just one "click" etc.
Big trucks have the aerodynamics of a brick so wind plays a big factor during your test. A full tank mpg check is going to be more accurate than over half a tank.
Old May 2, 2017 | 01:41 PM
andym's Avatar
andym
0.7 mpg is really not that much. There are a number of factors, most of which Ted listed, that impact mileage in addition to driving style, elevation changes, etc.
I would guess that you are within acceptable variance, and your observations are not statistically significant. The weight of the unburned fuel is a factor but a very tiny one and I can't think of any other reason why you'd see different mileage numbers based on the fullness of the tank.
If you were able to turn in mileage that was consistently 16.8 +/-0.1 on an empty tank and 16.1 +/- 0.1 on a half-empty tank, then that would be significant. But I know mileage records over a long period of time are never that consistent. You can see as much as 5 MPG difference from tank to tank depending on all those factors above, and the data just isn't going to be consistent enough to support the conclusion that tank fullness impacts mileage.
Old May 2, 2017 | 02:02 PM
LivingLarge's Avatar
LivingLarge
Diesel is about 7.1 lb per gallon so at half tank you have burned off 156 lbs approximately or the weight of a chunky wife. Theoretically you would get more mpg on the 1/2 tank to empty than full to half.
I can notice a huge difference on my boat when I'm down to half a tank (7100 lbs less) I see a 10-15 gallon per hour savings.
Old May 2, 2017 | 02:20 PM
Tedster9's Avatar
Tedster9
Originally Posted by LivingLarge
... at half tank you have burned off 156 lbs approximately or the weight of a chunky wife.
Objection! Assumes facts not in evidence your honor.
Old May 2, 2017 | 05:34 PM
SmackDaddy's Avatar
SmackDaddy
I must have bad driving habits because 11mpg average towing my boat and 14mpg without. Hmmm
Old May 2, 2017 | 05:42 PM
LivingLarge
I wasn't referring to towing a boat lol I was referring to fuel weight. As fuel burns off the lighter your vehicle gets. In the case with my boat it holds 2100 gallons of diesel.
Old May 2, 2017 | 05:53 PM
Misky6.0's Avatar
Misky6.0
When you fill up from nearly empty, you get more foam in the tank which results in less fuel going in. With half a tank, you get less foam resulting in more fuel going in.
Plus, your mpg varies during each commute, warming up compared to later in the commute. If you fillup on the way to work, you penalized the prior tank with the warm-up and the next tank benefits from a fully warmed up start. Did you stop for groceries, beer, etc. on this tank vs prior?
Things like this make it very difficult to make real comparisons, and a couple of WOT to get on the highway negate a day's worth of driving "boringly".
Twitchyleprechaun
I agree, and I don't think there is a good way to control all the variables. I may just start always running 'til empty and only putting in 20 gallons because it makes me feel better..
Over the next 2 months I will be doing 100 miles a day as a commute. I may be able to make sure I always fill up at the same station and drive the exact same way. I don't see traffic much on that route so I should be able to run constant speeds. This will allow me to see if there really is a difference over a short period of time.
That I could totally understand. I didn't think being 20 gallons down on the truck would cause a huge difference but I thought it was odd that the numbers were always fairly close to wait I said earlier.
HAHA
I try to be fairly easy on the pedal. When not towing, I try to keep my RPMS under 2000. I try to keep my showing off to a minimum as well, but that is sometimes very hard to do.
Old May 3, 2017 | 01:15 PM
Stewart_H's Avatar
Stewart_H
That only applies if you stop filling when the foamed fuel causes the pump to auto shut off. If anyone is like me, and fills their tank slowly until you see the fuel sitting in the neck, several inches from the cap threads, then the foaming factor is eliminated.
Stewart
Old May 3, 2017 | 01:18 PM
andym's Avatar
andym
No one is like you Stewart...
Old May 3, 2017 | 02:04 PM
Stewart_H's Avatar
Stewart_H
And the world breathes a very large sigh of relief.
(Me too. My brother being a lot like me is bad enough...especially because he's "worse.")
Stewart
Old May 3, 2017 | 02:36 PM
Twitchyleprechaun
I usually do the same thing. I will put the pump on the slowest auto notch and wait.
Old May 3, 2017 | 02:48 PM
Excurvelle's Avatar
Excurvelle
MPG in the summer is always low on mine, seems like it always has something attached to the trailer hitch.
Old May 3, 2017 | 03:03 PM
ExPACamper's Avatar
ExPACamper
I just put it on fastest setting and let it fly!
It will stop when the pre-auth limit of $100 is reached. That won't fill the tank here in PA, land of the "Tax 'em until they squeal"
I haven't seen a topped off tank since...what year is this?
