Injector hot torquing.
He's keeping in touch with his buds. LOL
And while we use inch lbs torque wrench for accuracy at such low levels, he did say 12 FT LBS, which is the correct conversion (or is it?). I am soooooo tempted to go out in the garage and sacrifice one of those injector bolts just to see what it's failure point is. I'll bet it's above 15 ft/lbs.
Edit: After researching it it's 144 in/lbs=12 ft/lbs.
And while we use inch lbs torque wrench for accuracy at such low levels, he did say 12 FT LBS, which is the correct conversion (or is it?). I am soooooo tempted to go out in the garage and sacrifice one of those injector bolts just to see what it's failure point is. I'll bet it's above 15 ft/lbs or 150 in/lbs.
Edit: After researching it it's 144 ft/lbs=120 in/lbs.
Either way, I will hot torque the bolts to 130 in/lbs when I replace my injectors.
I've tried cold re-torque - nope... fail. They work loose again. Drivers that I work with (not many, but enough) frequently comment how much quieter their truck is now.
Things mentioned here make me wonder...is it a 'hot' torque that is required or is it a 'retorque', which is needed after running? If it's this big of a problem why wasn't it an issue when these things were fresh off the line?
And one other thing...is it supposed to be a dry torque? A dry torque won't be as snug as a wet torque. The thought of oil there would lead us to believe that it might be inclined to loosen itself up but it also changes the pressure that is applied by the bolt head.
on
Tell me how you guys are getting near the engine when it's HOT to retorque
There is nothing quick about getting to my injectors, all that stuff on top.
Or are you running it without the CAC pipes and stuff, just idling in the garage for...how long? How hot? Idling or driving?
The way I work, it would be too hot to touch, gloves too clumsy, and it would be cool anyways by the time I got down to getting the valve covers off
Inquiring minds want to know!
on
You run it with the CAC pipes and valve covers off. I ran mine for about 45 minutes. I wouldn't drive it around, too much chance of something getting sucked into the turbo. In fact you want to make sure there are no loose bits of anything under the hood. You would be very surprised at how much air the turbo blows at idle, and how much air the engine requires at idle too.
45 mins at idle, eh? I have a fast idle tune, is that helpful?
Thanks
I didn't have to tie anything out of the way. The valves don't move that much.
#29
I'm pretty sure Rich utilizes a high idle tune. These engines don't make much heat at idle. Maybe if you could engage the EBPV at idle that would help make some heat retention in the heads.
Let's look what the heat changes. Heat make things expand....what is expanding at a different rate that causes the "Hot retorque" to be beneficial?
#30
If I go out to the garage and just start cranking on one of those injector bolts on the engine sitting out there, is there any chance that I would damage the head? I think the answer is a resounding 'no' but I am open to thoughts and experience. I could very easily go step it up 5 in/lbs until it failed.
