parallel O2 sensors
Old May 1, 2017 | 01:00 PM
kopfenjager's Avatar
kopfenjager
parallel O2 sensors
Can you run two O2 sensors in parallel? The voltage should stay the same and current would double but, O2 sensor test at infinite ohms so two infinite is still infinite, so current would stay the same also? I have a dual exhaust and would like to run a O2 sensor in each side.
Old May 2, 2017 | 02:56 PM
lee's Avatar
lee
Theoretically, yes.
But, I would run them to an A-B switch then to the meter.
Unless I am missing something I do not see any advantage to running them in parallel indefinitely.
Old May 2, 2017 | 09:08 PM
kopfenjager
to run fuel injection. just to get a read on all 8 cylinders instead of just 4.
Sep 8, 2012 06:47 PM
Talyn
Nov 2, 2007 05:13 PM
BURNSTOUGHFORD
1997 - 2003 F150
Feb 4, 2007 10:02 AM
Jrock909
Nov 16, 2004 07:33 AM
mgm5555
Mar 10, 2003 09:38 PM
