O2 sensor test?
Old Sep 8, 2012 | 03:52 PM
650's Avatar
650
O2 sensor test?
I`ve been testing my 1995 ford f.150 with a 302. Anyways I was checking to see if I have a bad O2 sensor (the truck smells rich in the exhaust and gets 6mpg). I read off my meter after it was warmed up readings of 0.06 - 0.28 volts. Would this indicate a bad O2 sensor? I read on Advance Autos website most O2 sensors switch back and forth from 0 to 1 volts? Any help or ideas is appreciated.
Old Sep 8, 2012 | 06:32 PM
Lead Head's Avatar
Lead Head
Reading an O2 sensor with a standard multimeter will not work. You'd either need an extremely fast graphing multimeter, or an oscilloscope.
Old Sep 8, 2012 | 06:47 PM
bashby's Avatar
bashby
Did you check codes? Low o2 sensor voltage is a lean mixture, so if it is actually rich (smell, black smoke) and reading lean its probably bad.
codyop
Jan 25, 2015 03:19 PM
Jrock909
Nov 16, 2004 07:33 AM
mgm5555
Mar 10, 2003 09:38 PM
KTMNealio
Nov 20, 2000 08:13 PM
