Minnesota Chapter Join Chapter, Leader: fordpower88
It's May already BS thread
Old May 23, 2017 | 08:23 AM
  #376
Big-Foot's Avatar
Big-Foot
Good morning fellas
Jim that really stinks on the pavers... I believe what Tom said makes sense too...
It might just be better to live with the cracks a couple of years and see if they are going to go anywhere.
Old May 23, 2017 | 09:51 AM
  #377
fordpower88's Avatar
fordpower88
Good morning crew!
Old May 23, 2017 | 11:54 AM
  #378
DieselCamper01's Avatar
DieselCamper01
I would think that a well made paver would not crack Jim. They should give between pavers and not crack. None of mine on my patio have cracked in 12 years. They were Borgart I believe. A poorly made compound could make them softer than a better made one. Which would be a typical Menards item unfortunately.
Old May 23, 2017 | 12:49 PM
  #379
fordpower88
Good afternoon everyone! Rain then sun then rain and currently back to sun....wonder whats next! Haha
Old May 23, 2017 | 02:34 PM
  #380
dlibson's Avatar
dlibson
S n o . . . . . . . .
Old May 23, 2017 | 03:12 PM
  #381
MisterCMK's Avatar
MisterCMK
This winter is never gonna end
Old May 23, 2017 | 05:34 PM
  #382
Big-Foot's Avatar
Big-Foot
Well some success today... The local shop has a super scanner that could reach into the Durango's brain and pulled out not only the problems with the ABS but it also showed a BUNCH of codes that my OBDII CanBus scanner had cleared!
It showed no wheel speed on the left rear.
Having replaced all the sensors, I was pretty confident that the problem was either in the computer or wiring. I started ohming things out and found one of the two wires showed 2.5M Ohms rather than 0 as the other one showed. Hmmm.. I started opening up the wiring harness to find a good place to solder in a new Home-run wire to the front of the truck. I unwrapped a bunch and started probing with a pin and meter. Looking at the picture here you can see what I finally noticed.. green crud right at the edge of the insulation. BINGO!!!! I cut the insulation away and spliced in fresh wire and shrink tubed and re-wrapped the whole 9 yards..
Yea! NO ABS LIGHT and the cruise control etc. now works....
Old May 23, 2017 | 05:41 PM
  #383
Big-Foot's Avatar
Big-Foot
Oh and something else interesting about Mopar ABS Sensors.
They are Hall Effect sensors which also have a diode in them. They will only ohm out in one direction (polarity)... Checking the AC output of the sensors does not work. Instead, you get a DC Pulse (the diode does that)...
I'm getting quite an education with this truck!
It runs really well right now and just took it into Faribault to go shopping.
We are pleased that this truck is working so well and that Jake had made a solid choice in vehicles...
Old May 23, 2017 | 07:52 PM
  #384
fordpower88
Good evening guys!
Glad to hear you got it figured out Randy.
Old May 24, 2017 | 05:00 AM
  #385
DieselCamper01
Good morning everyone.
Old May 24, 2017 | 05:22 AM
  #386
wildstang's Avatar
wildstang
VT Chapter Ldr
Good morning and have a productive hump day MN and Jay
Old May 24, 2017 | 05:43 AM
  #387
Big-Foot's Avatar
Big-Foot
Good morning fellas
  #388
dlibson's Avatar
dlibson
Morning everyone, almost to the long weekend!
Old May 24, 2017 | 05:49 AM
  #389
Racer5349's Avatar
Racer5349
Good morning Jay, Jim, Randy, Dave and MN.
Craigslist score last night for my garden shed project. Outswing French doors in the perfect width. This ought to class it up a little.
Old May 24, 2017 | 07:02 AM
  #390
Tom's Avatar
Tom
Good morning, everyone!
