Just spotted a transmission leak from where the driveshaft enters the transmission. Had the driveshaft out for new u joints and carrier bearing the other day and noticed a small dribble - didn't think anything off it. But there's a couple of drops on the bottom of the transmission today - doesn't seem enough to drip on the driveway but the front of the fuel tank is shiny.
Totally epic advice, problem fixed. Whoever put the last seal on also put the breather hole on the bottom. Screwdriver and hammer was all that was required to get the seal out. Bought a $2.50 3" piece of exhaust pipe to use to knock it back in evenly.
