Tail Lights...Integrated?
Old Apr 30, 2017 | 02:35 PM
RossBarnard's Avatar
RossBarnard
We have a 1958 F 100 that my boys and I are rebuilding. We have finished rewiring and everything working except for when you hook up the tail lights they stay on regardless of whether key is on etc. All grounds seem good, we have it hooked up as an integrated tail light, blinker/brake because thats how it came to us. Anybody know if these original sockets are integrated or not? The bulb thats in it is a two filament bulb. We do not have turn signal wires hooked up yet because putting in new steering column but I don't think that would cause this issue? IDK, any advice is welcomed. Thanks, Ross
Old Apr 30, 2017 | 10:36 PM
hotfalcoon's Avatar
hotfalcoon
Are you using the original pressure switch on the master cylinder? If so it might be stuck causing the brake lights to stay on constantly.
Old May 1, 2017 | 07:01 AM
willowbilly3's Avatar
willowbilly3
I agree. One of the first things I had to replace after my original shake down run. Stuck on.
Old May 8, 2017 | 02:14 PM
RossBarnard
Hey gang, sorry for the delay. Switch was good but we had the wire on the wrong post on the light switch. Thanks a bunch and sorry for the delay!
Old May 12, 2017 | 10:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If this is a Styleside, the tail lamp lenses thread into the tail lamp bodies that contain 'swagged in' sockets with wiring.
The Styleside tail lamp lenses and the bodies (B7C-13434-A Right & B7C-13435-A Left) are the same: 1957/60 F100/350; 1961/65 F100/250 4WD; 1961/66 F350; 1966 F250 4WD
The lenses are also the same as 1961/67 Econoline pickups and vans (with round lenses).
pittdog1977
Jun 3, 2014 09:53 AM
civiltech
Mar 28, 2011 12:39 AM
Sore Knuckles
Oct 20, 2006 12:14 AM
grandaddy's66
Sep 19, 2003 01:28 AM
fordbloodline
Electrical Systems/Wiring
Aug 31, 2003 04:37 PM
