Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Carb Needed
Old Apr 30, 2017 | 08:07 AM
skd91's Avatar
skd91
Carb Needed
Hey Guys I need some help on picking a replacement carburetor for my 1970 F800 Dump Truck it has a 370V4 motor with the Motorcraft/Holley with the Govener stuff on it. the thing has been rebuilt several times the guy that I purchased it from. the thing is burning gas like a PIG.
Running really rich, burns your eyes to be around it. the idle mixture screws in the front of the carb don't change a thing.
So I am looking for something out there that will bolt right on and work.
Advice Please!
Thanks!
Old Apr 30, 2017 | 10:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by skd91
I need some help on picking a replacement carburetor for my 1970 F800 Dump Truck.
It has a 370 4V motor with the Motorcraft/Holley with the Governer stuff on it.
The thing has been rebuilt several times the guy that I purchased it from. the thing is burning gas like a PIG. Running really rich, burns your eyes to be around it. the idle mixture screws in the front of the carb don't change a thing. So I am looking for something out there that will bolt right on and work.
370 wasn't available until 1979, has 7 valve cover bolts per side.
Your truck originally came with one of the following FT engines (5 valve cover bolts per side): 330 2V Medium Duty; 330 2V Heavy Duty; 361 2V or 391 4V
No such thing as Motorcraft prior to 1973. 1962 thru 1972: Auto-Lite. 1973 and later: Motorcraft.
Old Apr 30, 2017 | 08:21 PM
Destroked 450's Avatar
Destroked 450
These are good carburetors but don't like to be backfired, sounds like it's got a busted power valve or one of the incorrect size.
Like NumberDummy said if your truck is a 70 model and has a four barrel carb it should be a 39.
Old May 1, 2017 | 03:57 AM
skd91's Avatar
skd91
sorry must have been my fat finger, my truck is a 1970 F800.
Steve
Old May 1, 2017 | 09:21 AM
NumberDummy
You said this in post #1, but it doesn't have a 370, because this engine wasn't available until 1979.
Old May 1, 2017 | 06:12 PM
skd91's Avatar
skd91
YES it is a 1979!
Old May 1, 2017 | 06:14 PM
skd91's Avatar
skd91
My darn computer likes the zero!
thing has autocorrect on it and will change all kinds of things.
Sorry!
Old May 3, 2017 | 08:56 PM
bigcrunch's Avatar
bigcrunch
If the power valve is busted, check if the carb has the backfire valve in it to prevent this.
Carb may need to be completely dismantled and cleaned Sonic hot tank works best.
Also check throttle shafts for wear.
Old May 4, 2017 | 03:53 AM
skd91's Avatar
skd91
Ok the power valve is the first place I will start. Thanks
Old May 4, 2017 | 08:11 AM
tree medics's Avatar
tree medics
Did you not have any luck with www.autoline.ca. You asked this question before. You should be able to cross reference your carb # and find a rebuilt one.
That is how I got one for my 1985 F-700, 370 4-V. My carb # is C-7488. Your truck being older might be a different #.
Old May 4, 2017 | 09:24 AM
skd91's Avatar
skd91
went to the site, but they only went to F700 in 1979.and had only the steering gear box listed.
Old May 4, 2017 | 09:26 AM
skd91's Avatar
skd91
But I will do some digging on the number of your carb and see what I come up with.
Thanks !
Old May 5, 2017 | 09:25 AM
NumberDummy
YES it is a 1979!
D9TZ-9510-AY .. 370 4V Holley Carburetor / Carb ID tag number: D9TE-AYA or AYB (Motorcraft CA-2123) / Obsolete
1979 F600/800; C600/700 (C Series Tilt Cab); LN600/700 all except CA emissions.
No Ford dealer or obsolete parts vendor has any.
D9PZ-9A586-AB .. 370 4V Holley Carburetor Repair Kit (Motorcraft CT-1276) / Obsolete
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
Old May 5, 2017 | 10:52 AM
skd91's Avatar
skd91
Thanks!
Sorry for being a pain.
Old May 5, 2017 | 11:06 AM
tree medics
I've had that happen before where they don't list something. I called with the number on my carb. They gave me their carb number and my parts store was able to get it.
