Brake controller
Old Apr 29, 2017 | 09:13 AM
TLG's Avatar
TLG
Brake controller
2017 F350DRW pulling 41ft 5th wheel. This is the 4th super duty I've owned with the integrated brake controller. Every other truck I was able to lock the brakes with the lever. Towed for the first time with this truck and it will not lock the brakes with the lever. Doesn't even appear to be slowing it down when I use the lever. The brakes appear to be working, but something is completely different. Same camper as last year pulling with a 2014 F350 and it would lock them up with the settting of 7.5. I've tried changing the settings in the command center to "heavy brake" but did not make any difference. Any ideas?
Old Apr 29, 2017 | 09:23 AM
Desert Don's Avatar
Desert Don
I fdon't know about the '17, but in my '16, there is also a setting for either electric brakes, or electric/hydraulic brakes.....might want to make sure this setting is correct.
Old Apr 29, 2017 | 10:28 AM
mhoefer's Avatar
mhoefer
In addition to selecting electric, or electric over hydrolic, the is a low, medium, high effort, and then the 1-10 scale. Go back and verify, edit settings from low to high, and try 9-10. It won't actually lock the brakes like before, but as long as the truck is moving, it will apply more and more force, I tried coasting in neutral and it brought ebpverything to a stop at medium, 7.5, and your trailer is far larger.
Old Apr 29, 2017 | 10:31 AM
Snowman 8's Avatar
Snowman 8
Someone will have to help me out here because I haven't been in mine for a week but there is also a setting for heavy vs light trailers in the display.
Old Apr 29, 2017 | 02:02 PM
K A M's Avatar
K A M
Setting up trailer you have electric or electric over hydraulic EOH. Make the correct selection which I guess is electric. The EOH electric over hydraulic is like equipment trailer, low boys etc. Next is the size of the trailer Small Medium Large (I may have this worded wrong). If you have a 41ft trailer then select Large/Heavy then select your gain until it works. If it don't work on heavy with gain at 10 then you most probably need the brakes adjusted.
Old Apr 29, 2017 | 03:51 PM
crewzer's Avatar
crewzer
Yeah, the OM says the default setting is "low".
HTH,
Jim / crewzer
cecilt
Apr 4, 2017 10:51 PM
sullyt28
Nov 27, 2015 05:36 PM
FarmingF250
Sep 2, 2014 03:06 PM
jdadamsjr
All Things Towing
Jul 11, 2014 05:33 PM
Stebs
Mar 23, 2013 07:04 AM
