Differential break-in
Old Apr 30, 2017 | 10:29 PM
Painted Horse's Avatar
Painted Horse
How many work trucks do you think have a 1000 miles on them when companies pull the beds and install utility beds? I don't think a load in the bed or pulling a light trailer is much harder work than packing around a 2000lbs utility bed. Especially since most of those aftermarket beds stay on the truck for life.
Another example may be the Ambulance Prep. I doubt those trucks get 1000 miles on them before the weight of the ambulance body gets installed.
I try to put as many miles on the truck as possible before I hook up a trailer. but if I have to pull the skid steer or mini excavator before 1000 miles, I just take it gentle.
Old Apr 30, 2017 | 10:34 PM
Habemus Quattro's Avatar
Habemus Quattro
The warranty terms for commercial applications is different than retail consumers. Ford's liability isn't as high. The biggest difference is that those commercial application vehicles generally have fleet managers that do maintenance a lot more regularly and preventatively than your average consumer. Therefore you can be sure differential fluid is going to be changed out quite often so there isn't any harm in heating it up right out of the factory.
Your average off-the-street buyer is going to expect that fluid to last "lifetime," so Ford is trying its best to set up an ideal situation to get them past the warranty period.
Old Apr 30, 2017 | 11:00 PM
Desert Don's Avatar
Desert Don
As far as warranty is concerned;if Dana-Spicer or Ford-Sterling screwed up building the differential, I want the thing to break ASAP so that it is repaired on their dime, not mine!!
Now if I am the one that set up new bearings and gears in the diff, then yes, I am going to baby it along for a bit to make sure things are not overheating and heading for problems. But even then, if things seem to be running at proper temperatures, etc. and I need it to work......it will go to work.
Old May 1, 2017 | 06:46 AM
USSenator's Avatar
USSenator
Originally Posted by SDcrewzer
Other vehicle components to consider during the initial break-in period are the brake rotors, brake pads, and tires.
HTH,
Jimn / crewzer
I would guess that this has more to do with it than any differential or engine break in. Ford doesn't want people driving with a heavy load until the brakes are 100% 'seated' to the rotor.
The 1,000 miles was probably an average amount of driving that included several stops.
If they have someone who had a fully loaded trailer and needed a panic stop, the brakes may not stop the truck in the proper time.
Old May 1, 2017 | 08:59 AM
jm-bc's Avatar
jm-bc
Using that argument there should be no extra payload (no heavy hauling) in the truck either during break-in.
The trailer should have its own brakes. If no trailer brakes are present, the prudent thing is to be within the trucks GVWR.
Old May 1, 2017 | 09:18 AM
USSenator's Avatar
USSenator
Very true. Here is Ford's reason, from the manual. There are probably multiple reasons tires, rings, brakes, and other parts...
"You need to break in new tires for approximately 300 mi (480 km). During this time, your vehicle may exhibit some unusual driving characteristics. Avoid driving too fast during the first 1,000 mi (1,600 km). Vary your speed frequently and change up through the gears early. Do not labor the engine. Drive your new vehicle at least 1,000 mi (1,600 km) before towing a trailer. Make sure you use the specified engine oil. See Capacities and Specifications (page 422).
Do not add friction modifier compounds or special break-in oils during the first few thousand miles (kilometers) of operation. These additives may prevent piston ring seating."
Old May 1, 2017 | 10:11 AM
alloro's Avatar
alloro
Originally Posted by whodat_ford
So it sounds like I have nothing to worry about and I can tow a few thousand pounds without worrying. I bought this truck because I need to tow and haul things and sometimes you don't have the privilege to wait 1,000 miles.
Yep don't worry about it. Some people that say otherwise are more concerned over trying to impress you with what they think they know rather than just trying to help. So relax, enjoy, and tow(easy for the first 1K)!
Old May 1, 2017 | 01:03 PM
jjmcc2's Avatar
jjmcc2
So if there is something in the manual you don't agree with then draw a line through it and keep on doing what you want. You'll be fine. I think that is what most are saying.
Old May 4, 2017 | 06:14 PM
BCooke's Avatar
BCooke
On the rear, am I suppose to change the oil after 500 miles same as Yukon Gears break-in procedure?
On the less serious side,,,
On the tires, just saying, Ford did not give me all the proper info.
Mine has Michelins on it and according to Michelin: "New tires have to be driven a few hundred miles on dry roads to rid the tread of parting agents and antioxidants applied during production. Not until the tread has been slightly roughened will the tire be able to make its true gripping power felt."
Ford failed to tell me dry roads...
And our ambulance was properly broken it, 28 calls and it hit 1000 miles.
Old May 4, 2017 | 07:45 PM
82_F100_300Six's Avatar
82_F100_300Six
I watched a TFL episode on YouTube about an independent car transporter he had a big 11-16 dually and claimed to have had his rear end replaced twice.
Old May 5, 2017 | 07:00 AM
troverman's Avatar
troverman
You guys are nuts! I started towing with my 2017 dually just a few days after I got it. Less than 200 miles for sure. Not towing super heavy - just between 5 and 10k lbs. That was 7 months and 8k miles ago. I don't expect to have diff troubles for several hundred thousand miles. I'm also not going to be changing the fluid for several years at least.
The book says "don't tow for a thousand miles" but it didn't say it was bad to put 5,000lbs in the bed before 1,000 miles, did it? My dually is rated for 5,440lbs. What, exactly, would be the difference?
Not to mention - nobody knows if you've towed before 1,000 miles or not. It won't be a warranty issue.
Relax and tow.
Old May 5, 2017 | 08:13 AM
jjmcc2's Avatar
jjmcc2
Relax and tow.
Somebody does now....lol
Old May 5, 2017 | 08:24 AM
  #28
troverman's Avatar
troverman
Since the diff isn't going to fail, it won't matter...
Old May 5, 2017 | 08:44 AM
  #29
530ktmpilot's Avatar
530ktmpilot
Following proper break in procedures provides a higher probability that you won't have a premature failure down the road. Personally, I think its not worth the risk to disregard them. Will your differential fail prematurely? Probably not. Will it go 300k instead of 350k? Maybe.
In the end, engineers determined it would be beneficial to run it without towing. They didnt just make that up for the fun of it. True, it helps prevent warranty work and claims cost. Why in the world would anyone have an issue with that? They dont want your truck to break (while under warranty) and neither should you.
I'm sure you will be fine and understand some folks will be forced by circumstances to not strickly follow break in procedures. But choosing to simply disregard them because you don't believe in them? Sheesh!
Old May 5, 2017 | 09:22 AM
  #30
willynilly's Avatar
willynilly
its hard to say but i wouldnt count your chickens before they hatch. right away the oil turns pretty dark on a new set of gears. since theres no filtration system its not a bad idea to change it out but thats your call. any damage that may have been done is permanent now so i guess it wouldnt make much difference at this point
