Cup Holder Question
Old Apr 28, 2017 | 05:26 PM
1956Fatfenders's Avatar
1956Fatfenders
Cup Holder Question
In the greater scheme of things, this is pretty minor, but is there any way to remove those stupid rubber thingies in the console cup holders? I hate these things as they are too tight, and certainly don't work with a koozie on the can.
My 2012 F-150 FX4 had removable inserts and the can just sat freely, easy to remove and replace. I think you could roll this '17 SD and the cans would never fall out of the cup holder.
It appears the soft rubber nubbers could be removed, but thought I'd ask before wreckin' something.
Old Apr 28, 2017 | 06:25 PM
2009kr's Avatar
2009kr
Maybe you can swap out the inserts for the job #2 spring inserts. They work great.
Old Apr 28, 2017 | 06:34 PM
das_16's Avatar
das_16
Just to let you know they aren't springs those tabs are held with a rubber band type thing.
I took apart my friends job 2 to get part numbers but they are on back order till 5/20.
Old Apr 28, 2017 | 06:39 PM
jriltex's Avatar
jriltex
How did you remove the cup holders? Curious as I would like to do the same.
Old Apr 28, 2017 | 06:42 PM
1956Fatfenders
Newbie question - Please elighten me on "Job #2".
Old Apr 28, 2017 | 07:16 PM
jimzpsd's Avatar
jimzpsd
Second batch, round two with some refinements
Old Apr 28, 2017 | 10:10 PM
das_16's Avatar
das_16
Just pull up on the grey trim then pull back and if poops off
Old Apr 29, 2017 | 07:18 PM
reseehc_99's Avatar
reseehc_99
Are the new cup holders on both the bench seat and the console? I haven't seen or heard anyone mention the bench seat cup holders.
Old May 7, 2017 | 08:49 PM
matrix311's Avatar
matrix311
Can you list the part numbers? I have a job1 and I was wanting to put the job2 front cupholder retention clips in my job1. Is this possible to do? Is that what you are doing with your friends?
Old May 7, 2017 | 09:52 PM
das_16's Avatar
das_16
Part number still goes to the old cup holders that are on the job 1 trucks job 2 trucks are just as cheaply built one of my friends already busted that band.
Old May 7, 2017 | 09:57 PM
jriltex's Avatar
jriltex
Why do they always try and over engineer these items? In our 2011-2016 SD's the cup holders with the inserts were removable and worked great. Now we try and get fancy and just end up building crap till Job 3 or 4 when all the feedback is received. SMH. Not rocket science fellows.
Old May 7, 2017 | 10:05 PM
das_16's Avatar
das_16
not sure why they wasted resources on trying to reinvent the wheel. our 11-16 super duty cup holders had zero issues.
Old May 7, 2017 | 10:07 PM
AbitaPro's Avatar
AbitaPro
Good luck, Ford has been getting feedback since the introduction of 2015 F-150's, and it hasn't helped! I'm holding out hope that one day Ford designers will get back to what works great, what's comfortable and so forth. Until then it's cost cutting.
Old May 7, 2017 | 10:23 PM
Florit17's Avatar
Florit17
Why do they always try and over engineer these items? In our 2011-2016 SD's the cup holders with the inserts were removable and worked great. . .
There wasn't many things I disliked about my 2012, but those removable cup holder inserts were definitely one! . . . Remove the insert to fit a larger beverage bottle and I found myself driving with one hand on the bottle to keep it from shaking. And if your cup/bottle fit snug in the insert, that meant the insert would be stuck to it when you took a drink, then you either had to drive with your knee, pull the insert off and re-install it, or you had to carefully rotate your bottle each time you put it back so the insert would seat properly. If it wasn't one of those, it was me frantically looking for the lost insert I removed and carefully stashed somewhere so that I wouldn't need to go "test drive" a new truck to get a replacement!
Old May 8, 2017 | 08:53 AM
shortride's Avatar
shortride
Not sure if you guys are aware of it but the top portion of your cup holder will slide to the driver-side to allow you to use larger cups.
charles adams
Feb 10, 2019 12:27 PM
Notmeofficer
Jun 22, 2017 04:09 AM
Wagion
Jul 25, 2013 11:05 AM
eldorado73
Dec 20, 2010 12:52 PM
