1992 302 possible crank seal damage?
Old 04-27-2017, 04:13 PM
tsevrens's Avatar
tsevrens
tsevrens is offline
Hey everyone
Moving along in our 302 to BMW 318is engine swap.. I've pulled the crank pulley off along with the pulley bolt.
Picked up a harmonic balancer puller to make my life easier.. once the bolt was out, I removed the large metal washer exposing some rubber that looks squeezed out from inside.. I'm thinking this is a blown crank seal.. but I've never done this work on a 302 before. Hoping someone can help identify this.
I'm pulling the timing cover off anyways for some additional work inside but this is a bit suspect.. thoughts?
Old 04-27-2017, 04:27 PM
tsevrens's Avatar
tsevrens
tsevrens is offline
Ok with the balancer off this is what i see inside..
Old 04-27-2017, 05:37 PM
Conanski's Avatar
Conanski
Conanski is offline
I'd wager it is just some misplaced RTV silicone.. maybe the PO put a big blob on the crank key to keep it in place while the balancer was installed. There is a key in that keyway isn't there? If not that is the bigger issue, the seal looks fine in those pictures.
Old 04-27-2017, 06:22 PM
tsevrens's Avatar
tsevrens
tsevrens is offline
If by 'key' you mean this little slot that i see on the crank shaft.. then yes it looks like it's there...
Old 05-27-2017, 12:50 PM
mustangman711's Avatar
mustangman711
mustangman711 is offline
That "blob" of RTV Black Silicone is to help keep the Oil where it is supposed to be. Works in conjunction with the Crank Oil Seal.
Jon
Jdeshler
05-28-2018 10:18 PM
bullnose1985
10-17-2017 04:52 AM
steeltoes
05-13-2015 12:52 PM
wd13
09-24-2008 07:37 PM
JaBoney
05-05-2008 10:10 PM
Quick Reply: 1992 302 possible crank seal damage?
