Crank sleeve?
Old Sep 15, 2008 | 10:59 PM
wd13's Avatar
wd13
Crank sleeve?
A friend of mine emailed me asking this hard to read/understand question that I dont have an answer to. Partly because of the way he asked I think
Anyway here it is, any help is appreciated....
need help from you ford BIG block guys....
At my shop I have a clusterf#@k is a 1979 F250 with a 1973ish 429 police interceptor in it..
The timming chain cover had a crack in it leaking coolant.....
The original cover the crank seal came in from the back, The new replacement cover the seal comes in from the front....ok no big deal...
BUT the balancer is not what slides through the seal/cover is this crank sleeve thing. then the balaner buts up to it with the balance bolt etc.
there is a grove from hell in this thing.....replace it, WRONG not available from ford...
ok..repair sleeve like a "normal balancer" , WRONG yes the do make it,
BUT here is where it gets fun..the seal is not in the same spot, we agree right??
ok the new seal is not riding on the new repair sleeve area....just misses it by a c^nt hair.
needless to say leeks oil like a sum b!tch
what do I do?????
HELP.
<!-- / message --><!-- sig -->
Old Sep 16, 2008 | 10:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Get the right sleeve kit?
Two I know of are Timken and Fel-Pro.
One has a rolled-in end that fits over the end of the balancer/spacer. It can only go in one position.
The other has a rolled-out flare and can be positioned anywhere along the sealing surface.
Hope this helps...
Old Sep 16, 2008 | 08:32 PM
wd13's Avatar
wd13
Apparently he got the fel-pro sleeve which wont butt up to the seal. Another concern to him is that the original 429 sleeve didn't have a counterweight where as the new one does (which is for a 460) According to his parts supplier, one can't be had without the counterweight???
Old Sep 16, 2008 | 08:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The counter weighted spacer won't work with an internally balanced crank.
He may be looking at having one machined or have to find a functional one that's used.
Old Sep 16, 2008 | 09:03 PM
wd13's Avatar
wd13
Thanks for the all the info. I will be sure to relay it. Neither of us thought of it being internally balanced.
Old Sep 16, 2008 | 10:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hey, I'm just a noob.
But I do know that up until '79 or so the BB's were internally balanced and had no 'porkchop' counter weight.
The ONLY reason I knew about the 2 sleeves was that I failed on my first.
I can see not having a new part available for something that's been OOP for 30 years.
Perhaps someone that knows more than me can weigh in with some advice.
I wish your friend luck, it sounds like a cool project.
Old Sep 24, 2008 | 07:37 PM
johncart's Avatar
johncart
sleeve
total performance sells the sleeve for internal balanced BBF's. i was going to convert my 69 460 (basically a bigger 429) powersteering from under the timing cover to a belt driven version. i need this sleeve and the timing cover that doesnt have the pump inside it....you may need this sleeve also..
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 26, 2023 11:24 PM
1918ALF
Oct 5, 2013 05:22 AM
Stevan
Apr 14, 2010 01:40 PM
seth99max
Dec 9, 2009 02:09 AM
Hawkeye58
Feb 21, 2002 10:39 PM
