72 f100
Apr 27, 2017 | 12:01 AM
72 f100
Where can I find a front wheel hub for a 72 F100? I cannot find them anywhere.
Apr 27, 2017 | 12:08 AM
Quote:
Originally Posted by
Dnielson
Hub? As in a drum brake hub? I think I need to ask whether it's 2WD or 4WD... your reply is........
Apr 27, 2017 | 12:13 AM
HIO Silver
4wheel drive yes drum brake hub.
Apr 27, 2017 | 01:17 AM
Oy... a drummed Dana 44.. try Jeff's Bronco Graveyard. If no joy, then contact Boyce Equipment in Utah on the off chance they've got one.
Apr 27, 2017 | 08:50 AM
I tried bronco graveyard already couldn't find anything. I will try the other one though thank you.
Apr 27, 2017 | 09:27 AM
1972 F100 4WD
Dnielson
Where can I find a front wheel hub for a 72 F100 4WD ? I cannot find them anywhere.
Ford did not sell the hub by itself, it was only available with the brake drum.
C9TZ-1102-B .. Hub & Drum Assy-Use with 11" x 2" brakes / Obsolete
1969 F100 4WD & Bronco
from serial number F30,001 / 1970/75 F100 4WD & Bronco.
No Ford dealer or obsolete parts vendor has any.
Apr 27, 2017 | 07:16 PM
Also try for a hub and drum assembly from the JY's also. You might have better luck. Everybody might be telling you "no" because they didn't want to separate the two apart.
You can also try Hidden Valley Auto Parts in the morning. 602-252-2122.
19F10066
Jan 5, 2019 07:46 AM
Andres Enriquez
Dec 30, 2018 05:15 PM
88stepside
Jun 15, 2018 09:41 AM
79f-250custom
15
Oct 16, 2007 02:15 PM
Dr4J
Sep 19, 2004 07:40 PM
