Inner/Outer Fenders
Old Apr 25, 2017 | 07:56 PM
JefflovesF250s's Avatar
JefflovesF250s
Inner/Outer Fenders
All: Just a quick question to confirm my recollection re attaching inner & outer fenders.
The 5/16-18 J-nuts go on the inner fenders with the nut facing the tires, and the outer fenders go over top and attach with 5/16-18 bolts with "toothed", loose washers above the thread just under the bolt head, correct?
Any close-up photos that were posted would be a great help.
I did take pics while dismantling, but not detailed enough, darn, isn't 20/20 hindsight great!
Thx. Jeff
Old Apr 25, 2017 | 09:51 PM
resonateur's Avatar
resonateur
Jeff:
The fasteners go exactly as you stated. There's a photo here, but you can barely make out the bolt heads. These fasteners (or very similar) are available new from Auveco. If you need the part numbers let me know.
Old Apr 26, 2017 | 12:38 AM
JefflovesF250s
Resonateur: Many thanks for the photo, it is exactly what I needed. I have the Auveco no.'s and parts from their dealer in Vancouver. Jeff
Old Apr 27, 2017 | 01:48 AM
The Masked Rider's Avatar
The Masked Rider
How's your baby coming along Eric?
Old Apr 27, 2017 | 09:36 AM
resonateur's Avatar
resonateur
Way more detail than I ever anticipated it taking! But, when I look at the photo above, I'm reminded of how far I've come. The bed, fenders, hood in paint right now and the rest is going together slowly. I'll send you some photos when I'm home...thanks!
Old Apr 27, 2017 | 09:42 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I don't have any J-nuts between inner (apron) and outer fender. The bolts pass through outer, then inner and a washer and nut on the back side, but no J-Nut in those locations.
Illustration Section 160 Page 1 shows the detail. Definitely separate nut from below in the pics. Same as all 3 of my trucks here and all I've taken apart, too.
Chad
Old Apr 27, 2017 | 05:49 PM
6t6merc's Avatar
6t6merc
Jeff, I think I have some of the correct bolts for you, not Auveco though.
Old Apr 27, 2017 | 09:50 PM
resonateur's Avatar
resonateur
I apologize....mis-spoke! Chad is right, both trucks (65,66) I disassembled had the 5/16 bolts with a captive washer, but had flat washers and nuts on the underside. I'm pretty sure they were locknuts, as the replacements I bagged are "stover" (crimp lock) nuts. That's what I get for relying on my memory...and the reason why I bag all the original hardware. Hope I didn't screw you up, Jeff....sorry! The J-nuts are used on the grill and probably a few other areas....I guess that's why I bought a box.
Old Apr 29, 2017 | 09:54 AM
JefflovesF250s
TA455HO, resonateur, Thx again for the help & clarification in attaching the aprons & fenders.
TA, I' should have checked the exploded view diagram before throwing my question into the chat. I'll do that now.
Resonateur, no problem with the earlier advice, as my project in slo-mo, so I cogitate on each step before plunging in. I had not done any re-assembly on the fenders, just circling around cleaning bolts and getting ready.
Eric, thx, I think I'm good for fasteners,but would like to visit to see your F100 just before plunging in.
Thx guys, Jeff
GoldCo
Mar 27, 2016 06:09 AM
HEAVY100
25
Oct 23, 2011 08:26 AM
musicmanbiker
Nov 19, 2010 07:47 AM
teardropty
Sep 29, 2010 06:14 PM
skeleton
Sep 6, 2001 01:00 PM
