Air Conditioning issues
Old Jul 20, 2006 | 01:15 PM
rickyf's Avatar
rickyf
Unhappy Air Conditioning issues
i was wonderin if anyone has a/c issues.my a/c clutch does not work is doesnt get power to it either any ideas? help it hot leather.
Old Jul 20, 2006 | 07:07 PM
MisterCMK's Avatar
MisterCMK
The problem is most likely that the system is discharged. There is a pressure switch on the drier which is on the passenger side. This switch turns the compressor on and off. I would be willing to bet that the system is too low on refrigerant to turn on the compressor. You can either add more freon to it and hope it works, or you can get a gauge set and know for sure what the problem is. BTW, what year is your truck?
Old Jul 21, 2006 | 05:32 AM
marragtop's Avatar
marragtop
You can also jumper (temporarily) the high pressure switch. If the compressor comes on, then that's an indication that it's low on freon.
tr2162
Jun 1, 2025 12:55 PM
MrPettis23
Jun 19, 2013 08:42 AM
79 bronc
18
Apr 27, 2011 09:34 PM
beartracks
Aug 23, 2002 11:05 PM
