99 F250 SD V10 battery going dead over night
Like the title says, if it sits over night the battery will be about dead. The cables were replaced 6 months ago and are in good shape. I could not find and bad spots on the wires I can get to. One odd thing to note, with the key out of the switch I opened the passenger door to check the glove box light and the truck started chiming like I had opened the drivers door with the key still in the switch. Would that indicate maybe the key switch could be the issue? Thanks
Unhook the battery overnight. Load-test it before hooking it back up in the AM. If it fails the load test it's a bad battery. If it passes the load test, hook the battery back up and see if it starts it up. If it starts right up its time to ferret out the short. Do you know how to systematically trouble the trucks circuits to find shorts?
What's the alternator output at warm idle? Put a VOM on the battery when you shut it off to see how fast the VDC drops. It will drop off from say 14.5 vdc quickly but it should level off and sit at about 12.6-13.2 for a good surface charge. That surface charge reading should stay level for days in a good battery with near zero milliamp draw.
Nothing new except the starter and battery cables in October of last year. This was done out in the woods where the truck decided to not start after cutting wood for a few hours. Not the most fun I've ever had.
I have a Schumacker BT-100 battery tester. The battery after having sat for a couple days shows 12.8 volts and passes the load test just fine. I don't drive the truck much and after discovering I have an issue with it I have just left the battery unhooked until I get a chance to work on it. I see I posted my "nothing new" reply in the wrong spot.
When it comes to a parasitic battery draw, or if I think I have one, I just take it to a buddy I know (powerstroke specialist, transmission specialist) and he will charge me 1 hr shop time to check the draw. Much faster than trying to figure it out myself.
Thats what I suggest.
The only reason I suggest that is so you can get it figured out quicker.
I'm learning some new tricks with this one. The truck had been sitting for over a week when I first discovered the dead battery. I put in my spare battery and made my trip, then the truck sat overnight. It started the next day but barely. When I got back I disconnected the negative until I could spend some time figuring it out. I had never done a parasitic battery draw test before but I "think" I've traced it to the left rear of the truck. Thanks for knowing which questions to ask.
