fuel sending unit
Old Apr 24, 2017 | 11:36 AM
mrxf350's Avatar
mrxf350
fuel sending unit
I replaced the sending unit in my 92 f350 front tank. It was always reading empty and now its always reading way over full. Faulty sending unit?
Old Apr 24, 2017 | 12:20 PM
genscripter's Avatar
genscripter
The sending units on these old trucks and van are notorious for failing. Did you check the resistance on your new unit before installing it?
Does your gauge read properly on the other tank? If no, then you might have some bad wiring, bad selector valve wiring, or bad gauge.
Old Apr 24, 2017 | 12:55 PM
madpogue's Avatar
madpogue
Most likely a connection issue. Way past full equals infinite resistance (open circuit). Does it work normally on the rear tank? If so, check wiring between the selector valve and the front tank.
MFplowboy
Feb 13, 2017 06:35 AM
Odisvan
Apr 5, 2016 09:25 AM
thegringo
17
Mar 22, 2014 10:49 PM
Astars450
Aug 28, 2013 02:33 PM
moparmusclecars
Oct 25, 2011 09:04 PM
