Fleetrite Red
Old Apr 23, 2017 | 04:25 PM
Skydivelout's Avatar
Skydivelout
Fleetrite Red
I don't seem to be able to find the concentrate on their website. When you click on the concentrate one it shows 50/50 in the pic. The F350 I just got has green coolant ***** and I want to change it out ASAP
Old Apr 23, 2017 | 04:56 PM
schlepprock250's Avatar
schlepprock250
If I remember correctly I got mine from Truck Pro.
Old Apr 23, 2017 | 05:05 PM
Rikster-7700's Avatar
Rikster-7700
What year is your truck? The ELC will not play nicely with the early 99's.....
Old Apr 23, 2017 | 05:12 PM
Skydivelout
There in lies the challenge. Truck is 2001 F350. The truck has 283000 n the clock but engine was changed out 100000 ago and it has 99 PSD 250 written on it - literally in yellow paint. I did notice the engine seems to sit 'lower' than my F250, don't know if this is a 99 trait or the fact its 2WD.
Old Apr 23, 2017 | 10:19 PM
JoeF250's Avatar
JoeF250
This almost doesn't apply to me, I have a 2002. But is it just the injector cups or injector cup sealant it doesn't play nice with? Or is there more to it than that on the early powerstrokes? Curious mostly because I have a couple spare motors sitting around out of obs trucks.
Old Apr 23, 2017 | 10:31 PM
schlepprock250
It's the injector cup sealant.
Old Apr 23, 2017 | 10:40 PM
JoeF250's Avatar
JoeF250
So to be clear, should I ever need one of my spare blocks. All I need to do is replace the cups with new sealant, and I'd be good to go for elc?
Old Apr 23, 2017 | 10:49 PM
schlepprock250
Yep, there's a certain type of sealant for the cups and being able to use elc. Now my answers are sorta vague and I can't elaborate on the exact sealant to use. As you already see it's always a little slow here on Sundays. I'm sure one of our heavy hitters will chime in later.
But I do know it's not a cup issue.
Old Apr 24, 2017 | 07:22 PM
bigb56's Avatar
bigb56
Tractor Supply carries Rotella concentrate and I believe Rotella makes Fleetrite for IH
Old Apr 25, 2017 | 11:09 AM
Stewart_H's Avatar
Stewart_H
Negative, it's more than just the cup sealant.
All the info you need is found here in my "Gooch" thread:
Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Post number 5 has the info.
However, there are people who have changed the sealant and cups, and then ran ELC.
Stewart
Old Apr 25, 2017 | 11:23 AM
JoeF250's Avatar
JoeF250
Stewart
Thanks Stewart for pointing me directly to where I needed to look. The blocks in question are both 97s'. I think with the info you gave me I should have a good road map to make it elc ready should I ever need them or decide I want a forged rod motor.
Again, thanks
Joe
Old Apr 25, 2017 | 01:36 PM
Skydivelout
Stewart
Thanks! So just to be sure, cos I do not want to screw up! The number on the sticker on the valve cover is 1046420 DOM 26 May 99. The number on the oil cooler plate is the same. SO i should be good for ELC correct?
Old Apr 25, 2017 | 03:33 PM
Stewart_H's Avatar
Stewart_H
If those numbers are accurate, then based on the info Gooch has supplied, yes, that engine would be ok for ELC.
Stewart
Old Apr 25, 2017 | 03:35 PM
Skydivelout
Stewart
If they're right it means I have forged rods too
Old Apr 25, 2017 | 03:38 PM
Stewart_H's Avatar
Stewart_H
Real easy to check, just pull the inspection plug!
Stewart
PS - Thanks for the reps, back atcha.
landscapeguy
Mar 29, 2016 12:55 PM
Sparkplugless
22
Oct 13, 2008 09:01 PM
tndiesel
Nov 11, 2007 09:34 PM
TheDuke
Sep 3, 2001 07:11 PM
