Highboy front bumper
Old Apr 23, 2017 | 11:33 AM
Aaron Kendall's Avatar
Aaron Kendall
What is this? On my 76 Highboy I've got a little metal plate there, but I'd love to have D ring hook ups.
Old Apr 23, 2017 | 11:34 AM
Aaron Kendall
And where can I get this?
Old Apr 23, 2017 | 12:05 PM
lafermedavid's Avatar
lafermedavid
bump
looks like 67-72 ford
Old Apr 23, 2017 | 12:42 PM
JakeHan's Avatar
JakeHan
Looks custom, and looks like the pickup in the picture has a body lift? Don't remember the fronts of the frame rails being that visible. Have a buddy that built a front-mount receiver hitch that tied in similar to that, but I don't know of a commercially-available one for a dent...... The ears on that one look like they might be for a tow bar, maybe not.
Old Apr 23, 2017 | 03:06 PM
lafermedavid
OK I gotcha now,I took tube steel ,I think 5 inch ,and notched it pretty much copied the design Ford had with the thin walled highboy front ,remounted my springs.welded the D rings
Old Apr 23, 2017 | 03:53 PM
Aaron Kendall
I like that you have tow points in the front, but you are still able to keep the classy look of the stock chrome bumper. How durable are the tow points? Do you have build plans?
Old Apr 23, 2017 | 04:09 PM
lafermedavid
hb
I been winging it for years,just picked up rear window gasket and 1981-96 door seal today from percision,,,motor should be at my home in less than a month,,,,make it look like a truck again
Old Apr 23, 2017 | 04:19 PM
lafermedavid
hb
How durable are the tow points?I could probably hook them up and pull it up vertical,that tube steel is stout.I probably would only do this if your really getting into tearing the front of your truck apart.a nylon strap around the front axle would pull you out as well,,,,
Old Apr 23, 2017 | 04:24 PM
Aaron Kendall
I like to occasionally put her in the mud so I need to have easy tow points? They need to be strong enough to pull a 76 F250 highboy ranger XLT snatched out of the mud.
steve33444
39
Dec 5, 2014 08:46 AM
mofoco1
15
Mar 7, 2014 05:05 PM
stydel311
Jan 20, 2014 09:28 PM
CPT P
Nov 12, 2013 11:04 AM
RanchTruck07
Mar 8, 2012 03:13 PM
