dirty exhaust pipe
Old Apr 21, 2017 | 06:40 PM
boatman33's Avatar
boatman33
dirty exhaust pipe
I have a 2012 with 60,000 miles. for the longest time the exhaust outlet was clean, but now it is black inside. my friend has a 2015 with about the same miles and his is still clean. I just don't know if it's a problem.
Old Apr 21, 2017 | 07:23 PM
Ferguson65's Avatar
Ferguson65
Dpf is cracked. See your dealer.
Old Apr 21, 2017 | 11:18 PM
BOHAWG175's Avatar
BOHAWG175
It's his truck begging to be deleted.
Old Apr 22, 2017 | 07:23 AM
boatman33's Avatar
boatman33
thought about deleting but its under warranty for a while still. I bought it new as a double leftover. its only 3.5 years old. besides that it runs so good the way it is. can't tell anything is wrong except for the black pipe
Old Apr 22, 2017 | 07:30 AM
EO2SeaBee's Avatar
EO2SeaBee
As previously mentioned, you have a cracked DPF. If it is still covered under your warranty, have it replaced. They will run a bunch of tests on it for Ford to prove it is bad, and then they will order you a new one and install it. For now, you have a "factory delete" of sorts and your regens will be based solely on mileage.
I went through this exact same thing a few years ago with mine. After a year, I started to get soot deposits at the tailpipe, and could even catch a glimpse of smoke when giving it throttle from a dead stop, if I was watching my right side mirror when pulling out.
If you find that they won't warranty it for some reason, you can run with it like that until you start to get a CEL continuously, or spend the money that they WOULD charge you to replace it with another DPF, on a delete kit and never worry about it again - assuming you live in a non-testing area.
Old Apr 22, 2017 | 11:39 AM
boatman33's Avatar
boatman33
pretty much exactly what I was thinking. I'll have it replaced under warranty and that should be good for a while. thanks for the replies
1980302windsor
Mar 19, 2011 10:25 PM
jimvo
Sep 4, 2010 09:32 PM
reg1952
Nov 11, 2008 12:00 PM
Uglyhat
Exhaust Systems
Oct 19, 2005 01:48 AM
