1978 - 1996 Big Bronco
help!!
Old Jun 19, 2009 | 10:06 PM
jasmine.carrigan87's Avatar
jasmine.carrigan87
help!!
i had to scrap my plan of converting my bronco to efi andnow need to install a efi fuel tank for use in a carb setup... ihave no idea what i'm doing and i could really use some help and pics i need to know how to deal with the in tank pump, i have been told it's too much for a carb so i bought a pump and filter to mount externally but i dont know how to by-pass it or wire it.. any advice is greatly appreciated. i have an 87 bronco w 351w using a stock tank off a 95 model
Old Jun 19, 2009 | 10:49 PM
Aciancio's Avatar
Aciancio
you can use the in-tank pump. just use a pressure regulator, set it to 4-5psi(i think) and run a return line to bleed off the extra
Old Jun 19, 2009 | 11:23 PM
g_k50's Avatar
g_k50
Disconnect the in-tank pump but not the fuel gauge level sending unit. Connect the external pump to the tank fuel line as suggested by the manufacturer. That's what I would attempt to do. but explaining how to do it is harder than just doing it.
Old Jun 20, 2009 | 04:27 PM
jasmine.carrigan87
thanks bud, that's what i have been told... its the wires that i dont know what to do with but i'll give it my best shot... jasmine
