F100'site and 93 to 96 Jaguar IFS & IRS
#46
picture....
. Oh. That's a much better picture. Your correct. It looks strong enough . Once boxed all around that will be more than strong enough. Nice work. I'm hoping mine comes out that nice.
keep up the nice work & pictures.
. I just looked over your pictures.
if you are going to box your frame. How are you going to get your bolts tighten down. I put a spacer in my frame with 4 1/2 inch long bolts. You have those short bolts? How will you tighten them if the frame is boxed?
. My 4 1/2 inch boltd come up thru my frame. I'm putting 3 1/2 inch bolts thru spacers on my side plates. These will fit all the way thru my frame. The welded in spacers will keep the frame from collapsing under bolt torque. All bolts are grade 8
#47
Mill have 4” of ride height on 20” wheels. Here is the wheel bottomed out so yes the running boards will be on the ground when rested. Air it up to ride height and I’ll be 4” up.
If the math works, that’s where I’ll be. Lol.
#48
picture....
(Coyote motor)
fatfenders
86
02-26-2013 07:48 PM
HEAVY100
08-23-2011 05:20 PM
