Need help locating Pitman Arm
Even though I could make this work, I really do not want to do this install more than one time and would like to just go with the Ford(Saginaw made) steering gear box. To do so I need the right pitman arm. If anyone out there has a line on the correct 70-early 71 pitman arm please send it my way. I do have an option on the table for the later 71 style pitman arm but not the linkage and then I would have to buy that new upping the cost.
I can not seem to find one of these anywhere. If you have or know where one is, I'll even pay you pull it for me.
Bendix P/S: 1966/68 F100/250 2WD; 1969 F100/250 2WD before serial number D96,001.
Ford/Saginaw P/S: 1969 F100/250 2WD from serial number D96,001; 1970/79 F100/250 2WD & F350.
Ford/Thompson 'pencil neck' P/S pump is the same: 1967/77 F100/250 2WD & F350; 1969/74 Econoline; 1973/77 F100/250 4WD; Misc 1967/77 FoMoCo Passenger Cars.
Ideally I'd like to just core this one through my friends NAPA store for the Ford box, I would just need the correct pitman arm then if I am correct? Unless I use the later pitman arm and change out the linkage pieces right?
Although I could upgrade brakes and swap suspensions I'd like to keep this one more original because of the miles and history I have for it.
C7TZ-3590-F .. Pitman Arm-Use with Bendix P/S / Marked: C7TA-3590-L / Obsolete
1967/68 F100/250 2WD; 1969 F100/250 2WD before serial number D96,001.
No Ford dealer or obsolete parts vendor has any.
1. If I decide to use the Bendix box, it should bolt right up to my frame/tie rods and be usable even though I have a 71 right?
2. Now, if I want to keep my tie rods, etc. and go to the Ford/Saginaw box for the 1969 - EARLY 1971, I would need that box and the C7TA-3590-E pitman arm?
3. If I end up only finding the LATE 1971/72 and up pitman arm, I will need to change out my tie rods, etc? Does this sound correct?
Given its a 45+ year old truck new tie rod ends might not be a bad idea anyhow. If all of this is correct, I have the stuff to install the Bendix setup in hand. I would rather go with the less likely to leak Ford box plus I would like to install headers some time in near future and I think I read the Bendix does not work well with header clearance on the FE motors.
If anyone has a Ford/Saginaw pitman arm, at this point I will take either version!
I pulled this one off of a Saginaw box that was in a '75 F100 2WD.
Pitman arm for Saginaw PS gearbox on top.
Steering/Suspension Component Variations - FORDification.com
I may finally have a line on the late 1971 (M00,001) and up. Dang things fly off the trucks around here. I am resigning myself to the purchase of new tie rods and link and using this arm. If I was 2 days sooner I would have had the box and pitman arm for the 69-mid 1971 (mine falls in this category) off one at pick and pull. That's what I get for not checking the web page for 2 days. Although I did score the right firewall bracket for the power steering column. For some reason some not so smart guy gutted the top half of a perfectly good column and left the tube as well as the center shaft. (Barter material!)
The shorter Dentside Saginaw-compatible column bracket can be used but, they do slightly differ from the shorter Bumpside brackets.
Longer column support bracket from my '69 F100 manual steering column on the left, shorter power steering column bracket from a Bumpside that had a Saginaw box shown on the right.
Bracket for a Dentside with a Saginaw PS gearbox shown below. Notice the top hole is at the 1:00 o'clock position, as compared to the Bumpside bracket hole that's at the 12:00 o'clock position. If a person was going to use the Dentside bracket, a hole could be drilled at the 12:00 o'clock position and the other hole at 1:00 o'clock could be welded closed or, just leave the unused hole as-is.
How valuable is the column tube and center shaft on the PS equipped trucks? I know the manual steer/auto trans ones can be cut down to fit. But I figured I should pick it up in case some one doesn't want to cut one down and they could rebuild this one or at least use the tube/shaft and the upper portion of theirs to make a good auto/PS column.
) 1971 F250.
