4r100 rattle noise in park and neutral
I've got a 2001 E350 van with the 5.4 triton and 4R100 transmission in it. Has about 130,000 miles on it.
I was doing some work under it a couple of days ago and noticed a rattling noise coming from the front of the bellhousing. I can't hear it sitting in the vehicle or standing next to it but it's pretty scary sounding with my face under the inspection cover.
Shifting is smooth no noticeable problems there. Tranny fluid looks good, not burnt.
After further investigation the noise is only present in park or neutral. In drive it goes away. In park it takes a few minutes of warm up for it to begin starting as a light tap tap, eventually working its way up to a clatter once warm.
I know the 99 4r100 had some TC issues that sounded like this. Anybody ever have anything similar? It sounds like it's in front of the TC so I'm thinking the flexplate maybe?
Update:
Took the van to local recommended transmission place. Owner can't find the exact source of the sound but dropped the pan and found about a 1/4 cup of clutch and metal . He suspects the TC but can't prove it unless the trans is dropped.
Told me it was probably good for another 20k miles but that it would fail in the near future especially since changing the fluid would allow more chance for slippage. Rebuild is 2000-2700 depending on what they find when they open it up (ie needs new pump ect.).
I'd like the van to be reliable enough to take couple hundred mile trips without worry about being stranded so I feel like a rebuild might be the best idea.
Would y'all go with the rebuild or try to get them to drop in a re-manufactured transmission at that price?
Keny1
12-25-2021 05:13 PM
superdutyon37s
09-13-2017 09:26 PM
chunger
1997-2006 Expedition & Navigator
11-18-2013 11:25 AM
Xrious
12-17-2004 08:19 AM
