Computer Chips & Tuners
Timming For Propane
Old Sep 2, 2003 | 03:05 AM
plncrzy's Avatar
plncrzy
Timming For Propane
I have received MANY timming setting recomendations for my 1987 5.8lt(351) ford 3spd auto. I currently have it set at 25 degrees and I still have LOTS of power on the highway. I have been told to set as high as 45 degrees and as little as 15 degrees and yes ... both recomendations were from certified mechanics.
What do you think, I prefer to hear from people who have experience with propane.
Old Sep 2, 2003 | 09:38 PM
FTE Ken's Avatar
FTE Ken
Timming For Propane
What is the mixture you're running?
Old Sep 3, 2003 | 12:12 AM
plncrzy's Avatar
plncrzy
Timming For Propane
Sorry I do not know ...
I am running a 425 impco mixer,
the truck is solely on propane ... it is a propane rebuilt motor... not sure if it was rebuilt with hardened valves only or if it has higher compression pistons as well. all I know is that when I purchased the long block, I had a choice of a standard or a propane version. I took the propane version. as for setting the 425, all I did was turn the idle low speed mixture in until I heard it run rought and the turned it out 1/2 turn, the high speed mixture is set at 3/4" which is what was recomended as a start setting. I was told that I did not have to turn that one out any unless I lacked power but was also told that the 425 was more than large enough for a 351 and would likely never have to turn it out ever. The engine runs great, with oodles of power at all rpms ... I just took a 2000 mile trip (3000km) and averaged 12 mpg driving at speeds of 60 to 70 mph through the mountains.
Old Sep 5, 2003 | 01:28 PM
FTE Ken's Avatar
FTE Ken
Timming For Propane
Hmmmm.... I'm really not able to give you anything without knowing about the compression ratio, air/fuel ratio, etc. With those unknown, the best thing to do is advance it until you get detonation, then back it off a degree or two. Then try it again at wide open throttle.
