Computer Chips & Tuners
webmaster...
Old Aug 30, 2003 | 03:08 PM
true4.2's Avatar
true4.2
webmaster...
My ECU code is VLW2. The V may be a U, but I couldn't tell for sure. I think it's a V though. OH! Just so you'll know:
2003 F150 4.2L truck
XL Sport edition
2WD
5 speed
Single cab
8000 miles
only mod is a K&N filter
Hey, when you put a K&N filter on, are you supposed to unhook your battery for 20 minutes for it work right? Also, if there are any other parts like fans, rockers, or anything like that you know of that will help my truck, please tell me. Thanks in advance man!
Old Sep 2, 2003 | 02:53 PM
true4.2's Avatar
true4.2
webmaster...
the above face message is me waiting for a reply
joking! just joking!
Old Sep 2, 2003 | 08:51 PM
FTE Ken's Avatar
FTE Ken
webmaster...
Sorry, but you posted on a holiday weekend and I spent a great deal of it with my son fishing.... family first.
I'm catching up now.
Yes, we can program a VLWx chip. There are a ton of parts available for it, from mild bolt-ons to pricey additions. Check out the 4.2L forum section, we've got some guys there that have done quite a few surprising things with the 4.2L.
Ford computers are adaptive so its not absolutely required to unhook the battery. Given enough miles and key cycles it will learn. However, resetting the battary usually accomplishes it a lot quicker, within the 1st 100 miles.
Old Sep 4, 2003 | 07:48 PM
true4.2's Avatar
true4.2
webmaster...
what's a mid-bolt on?
and what chip-tuner would you have for mine?
Old Sep 5, 2003 | 12:55 PM
FTE Ken's Avatar
FTE Ken
webmaster...
Items such as as K&N filters and intakes, cold air systems, underdrive pulleys and exhausts do not affect programming and do not require custom programming.
Superchargers, aftermarket intercoolers, headers, larger Mass Air-Flow sensors, nitrous oxide, performance cams, performance heads, boost underdrive pulleys (for Superchargers), larger fuel injectors and higher than stock fuel pressure require custom programming in order to supply the correct air/fuel ratios and ignition timing. Also, axle size and/or tire size changes require custom programming only if you want us to recalibrate the shift points/speedometer for these changes.
The 4.2L gains ~19 HP and ~28 ft/lbs torque.
Old Sep 5, 2003 | 02:36 PM
true4.2's Avatar
true4.2
webmaster...
wow, that's pretty good! Where can I get it?!
Old Sep 5, 2003 | 02:37 PM
FTE Ken's Avatar
FTE Ken
webmaster...
http://www.motorhaven.com/customer/home.php?cat=8
Old Sep 5, 2003 | 05:19 PM
true4.2's Avatar
true4.2
webmaster...
thanks man
AJUSAcom
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 31, 2012 03:31 PM
syphr
3.8 & 4.2L V6
Feb 14, 2010 06:05 AM
homer4.2
3.8 & 4.2L V6
32
Jul 1, 2004 03:00 PM
davesmyth
1997 - 2003 F150
Oct 25, 2002 07:02 PM
Rc piston head
1983 - 2012 Ranger & B-Series
Jul 9, 2002 04:48 AM
