ME AGAIN
Old Apr 18, 2017 | 09:58 PM
mgerdau's Avatar
mgerdau
ME AGAIN
Drove my 55 F350 to town and back. But when I got home my rear axle was dripping oil and had sprayed oil over the underside of my flatbed. Got the flange off, had an argument with the castle nut but I won I need to replace it. Took off the seal retainer and took the seal out; it had the following number A-1205-G-683, from my manual the Ford #7EQH4676 (I think), the gasket #B6QH4507-A, Axle vent 8A 4022, Castle nut 351165S8MM85. Now I'm trying to find the parts with no luck. Anyone, know who I can order parts from?
Old Apr 18, 2017 | 10:41 PM
EBEAR's Avatar
EBEAR
Can't help with the parts but are you sure your vent is good ? The absolutely first thing to check when you have a diff leak is the vent . plugged vent + heated oil = leak . the oil will exit at he weakest point
Old Apr 18, 2017 | 10:51 PM
mgerdau's Avatar
mgerdau
Thanks EBEAR, I'm also changing out the vent. But the seal is very worn and needs replaced too.
Old Apr 18, 2017 | 10:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you looking at Parts List #72 in the parts CD? In there, I see seal p/n TCAA-4676-A, nut p/n 351159, 7/8"-20. Found the seal on eBay:
Ford rear seal #TCAA4676A plain encased O.D. = 3.06" & I.D. = 2.17" | eBay
NAPA also shows to sell it,
https://www.napaonline.com/en/p/NOS17184
Old Apr 19, 2017 | 12:15 AM
mgerdau's Avatar
mgerdau
Yes, I was looking at my CD. The castle nut on mine is 1 1/4 inch - 20, although the CD says its 1" - 20. The pinion threads are 7/8" - 20.
Thanks for finding the seal on ebay and napa! I'll check napa tomorrow and see if they have the gasket and a nut.
Monument Man
Apr 18, 2019 09:29 AM
aerohead34
Jun 7, 2012 08:04 AM
strokin'_tatsch
Nov 24, 2008 10:19 PM
Ford RV'er
Oct 6, 2006 04:54 AM
BigRyanKP
Mar 27, 2005 08:54 PM
