Mystery Plug
Old Apr 18, 2017 | 11:01 PM
Cojamo83's Avatar
Cojamo83
Old Apr 18, 2017 | 11:03 PM
Cojamo83's Avatar
Cojamo83
Sounds great! Also I posted the pics so y'all could see this rats nest I'm trying to work through
Old Apr 18, 2017 | 11:20 PM
ctubutis's Avatar
ctubutis
Originally Posted by Gary Lewis
By the way, I'm having the Okie FTE get-together in September here at my place in Podunk.
Fixed it for you, Gary.
Old Apr 18, 2017 | 11:25 PM
ctubutis's Avatar
ctubutis
Originally Posted by vjsimone
In the case anyone is wondering; This is a; "1985 f150 with a 300 and a spd manual. "
Ah, thank you, I just began reading this thread (2-pages long already) and so I'm wondering what's going on... and so I see....
I will need to google-earth it, that might be an interesting place to stop by.... with ND....
As for the computer/mechanics, I have intense fears already....
Old Apr 18, 2017 | 11:32 PM
ctubutis's Avatar
ctubutis
Oy... I just read through the entire thing....
Oy.......
Show us your distributor, this thing might be better off left as a farm truck....
Old Apr 19, 2017 | 09:00 AM
Cojamo83's Avatar
Cojamo83
So it "appears" that all the plugs are still hooked up and intact on the distributor. These are the best pics for now. I snapped a couple on the way out the door to work
Old Apr 19, 2017 | 09:02 AM
Cojamo83's Avatar
Cojamo83
First encounter with an electronic controlled carburetor and distributor. I have a lot to learn and that's exactly what I would like to do if possible. I'd like to learn with this truck and not just start taking parts off. Y'all have been great. Thanks
Old Apr 19, 2017 | 09:12 AM
Gary Lewis's Avatar
Gary Lewis
That certainly is a computer-controlled dizzy. So, unless everything is intact and working the computer won't be happy.
Old Apr 19, 2017 | 09:36 AM
ctubutis's Avatar
ctubutis
Yeah, that's the grey TFI thing, it will be lots happier with everything at least hooked up and, ideally, working.
OK, go ahead and get that EVAP valve hooked up again, the computer certainly knows about that problem and would be throwing a CEL (MIL) on the dash if these trucks had one. It's not exceedingly difficult at all to ask the computer what it thinks is going on but it takes some patience.
Which reminds me... Ray over in France is kinda in the same situation, but with more advanced built-in diagnostics... but I have virtually zero idea of how the French run their systems, and I don't have any French books and so can't help there myself but the aftermarket offers varying degrees of help in figuring that stuff out...
Old Apr 19, 2017 | 12:37 PM
Cojamo83's Avatar
Cojamo83
So on more question...at least for today. I won't be able to get a factory air cleaner for a few weeks, until I can make it to the salvage yard. Obviously I'm not going to be able to keep my hands off of a truck that begs to be driven. What will need to be addressed as far as not having the air cleaner? Vac lines/electrical.
Old Apr 19, 2017 | 12:45 PM
Gary Lewis's Avatar
Gary Lewis
Probably nothing. The factory air cleaner had a hose for the thermostat so it could control the inlet air temp to the carb. But, surely the PO plugged that when he put the itty bitty air cleaner on. Surely?
Old Apr 19, 2017 | 12:49 PM
1986F150six's Avatar
1986F150six
I am late coming to this party... how well does the truck run?
Old Apr 19, 2017 | 01:36 PM
  #28
Cojamo83's Avatar
Cojamo83
When I got the truck I drove it about 2 miles to my house. Truck ran (sort of) would not idle for anything. Carb was flooding bad. Took carb off and rebuilt. Float was way out of adjustment. Have not put the carb back on yet becuase in the process of removing and rebuilding the carb is when I learned of this magical thing called an electronically controlled carb. Never seen one before. That's where I'm at right now. Trying to get as much of the vac and electrical worked out so when I get the carb on I have the best chance for everything running and then I can figure out what direction I want to go with motor.
Old Apr 19, 2017 | 01:50 PM
  #29
Gary Lewis's Avatar
Gary Lewis
David/1986F150Six has quite a bit of experience in this area, so I'll bow out and read the mail.
Old Apr 19, 2017 | 02:57 PM
  #30
1986F150six
Check very carefully for any and all vacuum leaks. All sensors [MAP, O2 sensor, temp. for the computer, etc.] must be connected and functioning for the computer to be able to control the system.
