E4OD Problem
Old Apr 18, 2017 | 07:14 PM
Lalondec's Avatar
Lalondec
E4OD Problem
hey I'm new to the site but I wondering if anyone could possibly give me some info on what to check. My 97 f350 7.3 is acting up. I started it the other day and went to put it in drive and the engine died. I looked through about 10 different sites and some are talking about the TCC. The engine will only die when shifting to drive, not reverse. The trans fluid is full. I unplugged the solenoid pack yesterday and the connector looks good. The truck hasn't die since I unplugged it and plugged it back in. Engine rpms drop down every once in a while when I'm shifting from park or when I'm coming to a stop. I was thinking that maybe that was helping cause the engine to die. Any help is very appreciated.
Old Apr 18, 2017 | 09:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low trans fluid can do this.
Old Apr 18, 2017 | 09:38 PM
Lalondec's Avatar
Lalondec
I checked it after i got back from where I was going and the level is where it should be. It shifts hard more often now. I have the CEL on but I don't have anything to pull codes with.
Old Apr 19, 2017 | 08:39 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Where are you located
Old Apr 19, 2017 | 10:25 AM
Lalondec's Avatar
Lalondec
I'm in Michigan
Old Apr 19, 2017 | 11:45 AM
97-psd's Avatar
97-psd
Obviously, getting the codes read is the next step. Hopefully someone is close to you that can help you out and read them for you
Old Apr 20, 2017 | 12:18 PM
Jarrett Campbell
That is a little bit of a drive for me. Sorry man
Old Apr 20, 2017 | 12:26 PM
cowmilker08's Avatar
cowmilker08
Agreed!
Here is a cheap investment you should look into: https://torque-bhp.com/
Old Apr 20, 2017 | 09:51 PM
Lalondec's Avatar
Lalondec
Hey Mark, my buddy has a E4OD with transfer case out of his 95 Ford. Would that work on my year. If so is there anything I'd have to change or modify? Thanks.
Old Apr 20, 2017 | 09:52 PM
Lalondec's Avatar
Lalondec
Originally Posted by cowmilker08
Agreed!
Thanks for the advice. I'm looking into that now.
Old Apr 21, 2017 | 09:18 AM
Mark Kovalsky
It depends. What engine is in each truck?
Old Apr 21, 2017 | 10:44 AM
Lalondec's Avatar
Lalondec
Mine:7.3 my buddy had 351
Old Apr 21, 2017 | 10:58 AM
knottyrope's Avatar
knottyrope
that wont bolt up, wrong bolt pattern
Old Apr 21, 2017 | 11:04 AM
Lalondec's Avatar
Lalondec
Alright thanks
Old Apr 24, 2017 | 09:44 PM
Lalondec's Avatar
Lalondec
Had a guy come a scan my truck but the forscan won't connect to show DTC. The truck is now dying when I put it in reverse also. It's done it about twice now.
