1986 amp gauge bouncing
Old Apr 18, 2017 | 09:10 AM
Rich G's Avatar
Rich G
Hi All,
A friend of mine has an 86 and the amp gauge bounces just sitting there.
I checked the voltage and its around 14.5V at the battery, it fluctuates slightly between 14.4-14.6 or so but I have a hard time believing this would show up on the gauge.
Any thoughts?
Old Apr 18, 2017 | 09:37 AM
CountryBumkin's Avatar
CountryBumkin
How much bounce?
You would want to check amperage. A clamp on amp meter would work.
14 volts says alternator is charging but maybe the regulator (or alternator) is bad and the alternator is quickly switching back and forth from charge to no-charge causing the gauge bounce. It may not be noticeable measuring voltage since the battery acts like a shock absorber and can mask fluctuations.
If you can't check amperage, I would first check the grounding of the voltage regulator (you could run a jumper from regulator case to engine ground) or just replace the regulator. If that doesn't help, you could take the alternator to part store for bench testing.
Of course it could also be a faulty gauge and/or wiring.
Old Apr 18, 2017 | 10:58 AM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by CountryBumkin
How much bounce?
Well said!
Old Apr 18, 2017 | 04:52 PM
Franklin2's Avatar
Franklin2
Simple enough. If the headlights are blinking with the amp gauge, I would investigate. If not, I would not worry about it.
samahi72
Aug 25, 2016 07:32 PM
supercab blue
Aug 26, 2004 07:52 PM
turbogus
Feb 9, 2004 11:46 PM
n3ffn
Electrical Systems/Wiring
Mar 10, 2001 09:54 PM
