Starter solenoid issues
Old Apr 17, 2017 | 11:11 PM
Lauraroka's Avatar
Lauraroka
I have a 1976 f150 that I recently put the body back on the frame.
The solenoid won't engage to bring power to the starter motor and I replaced the solenoid and still doesn't work.
I have power to the small black wire (middle right of solenoid) when the key is in the "Run" position and power on the small red wire (middle left of solenoid) when the key is in the "start" position. But I still can't get power going to the starter wire !?!
Old Apr 18, 2017 | 10:34 AM
lasermike's Avatar
lasermike
Do the solenoid terminals have letters near them?
"S" would be for the start position of the key and "I" bypasses the ballast resistor. It sounds like you have it right from your description but left and right depend on point of view. If your left and right are from looking across the engine and not from over the fender, you have it right. You can jump the big terminal from the battery directly to the small terminal next to it and it should pull in.
Also, the solenoid must be grounded, usually through it's mounting bolts to the inner fender.
Michael
Old Apr 18, 2017 | 03:05 PM
DB429SCJ's Avatar
DB429SCJ
Make sure you have ground wires from the engine to the body and the frame.
Old Apr 18, 2017 | 03:11 PM
Lauraroka's Avatar
Lauraroka
The solenoid was not grounded properly. I cleared up some of the paint and the engine turn over right away
Thanks for the help guys!!
Old Apr 18, 2017 | 06:41 PM
PapaBearYuma's Avatar
PapaBearYuma
Welcome to FTE - lots of good people here and often willing to help!
Glad you're starter solenoid issue had an easy fix.
When you get a chance, post up some pictures...we love pictures!
Gotanoldtruck
Oct 26, 2013 07:27 PM
rwk26164
1997 - 2003 F150
Dec 24, 2011 03:35 PM
fordpower46
May 8, 2009 08:53 PM
Kitester
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 3, 2005 08:36 PM
homer
Sep 20, 1999 11:36 PM
