need help with 5/16 inverted flare nut
Old 04-17-2017, 04:18 PM
gary's1950F1's Avatar
gary's1950F1
gary's1950F1 is offline
I'm looking for a long 5/16 inverted flare nut for my transmission cooling lines. I need the long ones that go in the bottom of the radiator. I've been to every parts store in the area and no one has them. I've even tried radiator shops. The radiator I'm putting my 50 is out of a 1978 F 150.
Old 04-17-2017, 04:21 PM
Ct70's Avatar
Ct70
Ct70 is offline
Go to a heavy truck shop ,we use them on air systems in trucks .
Old 04-17-2017, 04:41 PM
gary's1950F1
Like Kenworth or Peterbuilt?
Old 04-17-2017, 04:44 PM
Ct70's Avatar
Ct70
Ct70 is offline
Definitely ,but any truck shop ,heavy equipment shop should be able to fix you up .Also a plumbing supply place ,they have brass fittings like that as well .
Old 04-17-2017, 04:47 PM
gary's1950F1
ok thanks I'll give them a try.
Old 04-17-2017, 04:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
NAPA has them, too.
Old 04-17-2017, 07:31 PM
gary's1950F1
I've been to 3 NAPA stores they didn't have anything.
Old 04-17-2017, 08:08 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
buy a foot long length of pre-flared 5/16" line that comes with the nuts and take them from there. Every auto parts store has them.
Old 04-17-2017, 08:11 PM
gary's1950F1
Tried that all the newer 5/16 line come with the short flare nuts now
Old 04-17-2017, 08:19 PM
drptop70ss's Avatar
drptop70ss
why do you need the longer nut, is the seat that far into the radiator? The nut bottoms out before it tightens? You could make a small sleeve to go between the nut and the flare so that the sleeve pushes the line into the radiator while tightening the nut.
Old 04-17-2017, 08:24 PM
gary's1950F1
Yes I need the longer nut . It bottoms out before it tightens on the line. Something like a small sleeve might work. I was just hoping I could find the right nut. I'm going to try a few junk yard and see if I can find some old ones and just cut off the nut.
Old 04-17-2017, 08:27 PM
drptop70ss's Avatar
drptop70ss
For a sleeve you may even be able to just use a small section of 3/8" steel line, maybe 1/4" long. Put the short nut on the line, the sleeve, and make the double flare. As long as the sleeve will slide into the port without hitting the threads it will work, and the sleeve could be cut and the diameter made smaller as needed.
Old 04-17-2017, 08:33 PM
gary's1950F1
Thanks if I can't find the right ones I'll give that a try Its just hard to believe they stopped making the longer nut in 5/16.
Old 04-17-2017, 08:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've got one, is that all you need? My only concern is that it isn't threaded all the way, see pic. It's like it has the bushing Dave was talking about, built-in. It's about 3/4" under the head.
Old 04-17-2017, 08:55 PM
gary's1950F1
I need two but if that' s for 5/16 line it's a start how much do you want for it?
Quick Reply: need help with 5/16 inverted flare nut
