Ok so I was wrong on the wire hahaha. Mine was just a burnt off wire with no connector when I found it so I figured this one was either the fuel bowl heater or the filter sensor. Turns out it's the filter sensor. Thanks for correcting my misinformation fellas
Got it - to FoMoCo tomorrow then. Hopefully that fixes it as I'm assuming with no oil pressure this thing ain't gonna run
Oh yeah, it would have quit running a long time ago. You try squeezing the clamp onto the post? My last OBS had the same issue, but it was a bad sensor the previous owner put on there. FOMOCO sensor fixed it right.
