odd glitch
Old Apr 16, 2017 | 06:00 PM
kylant's Avatar
kylant
odd glitch
just had an odd issue...
hopped out of the truck, ran into the store. came back and went to start the truck, it would just crank briefly and stop. it did this a couple times, then finally cranked and started like normal.
also the light dimming gauge was on and the cluster was on the my key screen, i never have it on that screen.
also the other day the shifter would not come out of park, said no key detected (i have police mode enabled).
could this be a sign of a dying fob battery? any thoughts?
thanks
Old Apr 16, 2017 | 06:07 PM
bridge's Avatar
bridge
Sick 'n Tired
Could be, to be safe I'd change the battery. Or it could just be one of those things that happens with these overly electronic trucks. I couldn't get my remote start to work for three days last week. Then one day it just decided to start working again. Electronic gremlins.
Old Apr 16, 2017 | 06:09 PM
Chris Crews's Avatar
Chris Crews
Doesn't the fob have a slot like most cars with only a fob that you slide it into to charge the battery?
Old Apr 16, 2017 | 06:17 PM
bridge's Avatar
bridge
Sick 'n Tired
The Intelligent Access fob takes a CR2032 battery, it's not rechargeable. Interestingly enough, according the manual, the information display will alert you if the fob battery is low. Good to know, as this is why I didn't enable Police Mode for fear that a dead fob battery could leave me stranded.
Old Apr 16, 2017 | 06:22 PM
FOURBYBUD's Avatar
FOURBYBUD
Mine did that the other morning at 4am as we were leaving for vacation. Never done it since. Hmmmm. On another note, what is Police mode?
Old Apr 16, 2017 | 06:34 PM
wb6anp's Avatar
wb6anp
Secure idle mode, Cant shift into drive unless the FOB is in the vehicle.
Old Apr 16, 2017 | 06:36 PM
kylant's Avatar
kylant
i'll replace the fob battery and go from there.
any thoughts on truck batteries?
police mode keeps the shifter from coming out of park if the vehicle is running unless the fob is detected.
Old Apr 16, 2017 | 06:37 PM
FOURBYBUD's Avatar
FOURBYBUD
Thanks wb6anp. How is this feature enabled?
Old Apr 16, 2017 | 06:39 PM
bridge's Avatar
bridge
Sick 'n Tired
You must use Forscan...or ask the dealer to do it.
Old Apr 17, 2017 | 07:17 AM
kylant's Avatar
kylant
replaced the battery in the fob, will see if that was the problem.
FYI the battery in my fob was a 2450, not a 2032
Old Apr 18, 2017 | 06:39 AM
danr1707's Avatar
danr1707
Isn't there a place to put the fob and bypass the RF, so it will still start if the battery is dead?
Old Apr 18, 2017 | 08:14 AM
railrode1's Avatar
railrode1
It's under a tray below the left side cupholder.
Old Apr 18, 2017 | 08:27 AM
danr1707's Avatar
danr1707
So, no need to worry about enabling the Police Mode?
Old Apr 18, 2017 | 08:58 AM
kylant's Avatar
kylant
i am thinking about disabling it. but i run into the store with the truck running all the time.
how far can a thief get without a fob??
Old Apr 18, 2017 | 06:07 PM
kylant's Avatar
kylant
well truck hasn’t done the no crank thing.
however, I now have a MIL (code 203B) that came on today. And, several times upon start-up today, the “service brake system message” pops up on the dash at start-up. It disappears right away and the brakes seem fine, no abs light.
Thoughts??
