Fuel pump relay
Old Apr 15, 2017 | 09:45 PM
77shorty's Avatar
77shorty
Fuel pump relay
Can anyone tell me where the fuel pump relay is on a 1977 f150 4x4 400cu in
was putting my boat in on a very steep ramp and while unloading noticed a change in engine idle from smooth to rough then it died and would not start again. I had to get towed up to level ground almost no fuel in the inline fuel filter and I am guessing it is the fuel pump as today running down the road it began missing cutting out and almost died. It recovered and I made it home. I figured I would change the inline filter and check the relay but can't seem to locate it. Thanks for the help.
Old Apr 15, 2017 | 10:14 PM
corvair62's Avatar
corvair62
I don't think your factory pump would have any kind of relay. They are mechanical.
Old Apr 15, 2017 | 11:28 PM
PapaBearYuma's Avatar
PapaBearYuma
Your truck came with a block-mounted mechanical pump. If somebody has added an electric fuel pump, there's no telling where the relay is. In fact, it's entirely possible that the electric pump is wired directly to an ignition hot.
My F350s have relays for my fuel pumps, and they're mounted on the driver's side fender, near the auxiliary battery
If your pump is wired to an ignition hot, the most likely place is the three position yellow triangular receptacle behind the dash
Old Apr 16, 2017 | 01:29 AM
77shorty's Avatar
77shorty
thanks for the info I think I found it
themicro
Aug 8, 2012 07:39 PM
freckler
Jan 3, 2011 09:02 AM
themicro
Electrical Systems/Wiring
Nov 2, 2006 03:24 PM
karlg
Jan 4, 2005 08:57 AM
GREG90
Dec 12, 2003 08:38 PM
