Originally posted by Ford_Six These following numbers are for Motorcraft/Autolite carbs. This number can be found on the side of the float bowl, right behind the accelerator pump rod, inside of a circle. The number on the right corresponds with the cfm rating on the left. Thanks to chas1234 for these numbers.
I found a Motorcraft 4v at a swapmeet, it have the numbers 1.25. Is that a 360cfm? The electric choke doesn´t work, anyone knows how to fix it or can I converte it to manual choke?
What the nubers actually are is the diameter of the venturis. This would be about a 725cfm carb. You first need to figure out what it came off of. Does the carb have a metal tag attached to it? If you post the numbers off that tag, we can tell you what it is.
