Mr Miller
Old Apr 15, 2017 | 04:41 PM
Andrew S Miller's Avatar
Andrew S Miller
Mr Miller
how do you determine if the amount of water in diesel fuel is to much, and caused the hPFP to fail?
Old Apr 15, 2017 | 09:40 PM
Iowa Ford's Avatar
Iowa Ford
Mr. Miller, Look for signs of rust on the components in the HP system.
Hope this helps. You could try doing a search on the topic. I know it has been covered here a few times. Good luck and Welcome to FTE !
Old Apr 17, 2017 | 04:16 PM
Dakster's Avatar
Dakster
Mr. Miller - Welcome to FTE as well. Usually by the time the Water in Fuel light comes on, it's too much. Ford will say, if it's enough that it makes it past the HFCM (lower fuel filter) it's "too much". It will cause rust and that will be the cause of failure.
Not saying I agree with that, since it is known in the industry that the CP4.x pump is super duper sensitive to water and it's almost impossible to stop ANY watre from getting past the filtering system.
Chadaddison
Aug 23, 2018 02:32 PM
RickBraden
6.7L Power Stroke Diesel
34
Dec 26, 2015 11:14 AM
tolliewolly
37
Jan 17, 2014 11:26 PM
blue oval fan
Apr 26, 2013 05:08 PM
blieux1
16
Dec 24, 2012 09:52 PM
