Bronco II Ford Bronco II
steering issue
Old Sep 1, 2003 | 09:51 PM
Cyanide96VR6's Avatar
Cyanide96VR6
steering issue
My 88 B2 will pull hard to the left one moment then after i make a turn, it will pull hard to the opposite direction. But on the highway, it runs perfectly straight.....any ideas??
Old Sep 1, 2003 | 09:54 PM
knucklehead11's Avatar
knucklehead11
steering issue
On rare occasions, mine will pull to the left normal, pull to the right when braking, and won't have as much power. Turn it off for a little bit, go for a drive, and everything's back to normal. I dunno what it is, but as long as it drives, I don't care.
Old Sep 1, 2003 | 10:47 PM
GrayRanger4x4's Avatar
GrayRanger4x4
steering issue
It could be a couple of things,Tie Rod ends ,bad Ball Joints or a bad power steering pump{not working at slow speed} I would also check the belts.JM.02W.
