tune up for 302
Old Apr 14, 2017 | 09:24 PM
BeauF0RD's Avatar
BeauF0RD
tune up for 302
Is there a thread on what all should be done or replaced to accomplish a full tune up on a 302 engine?
Old Apr 15, 2017 | 12:00 AM
boingk's Avatar
boingk
Its not that hard, there are only so many things you can do.
Hydraulic valves are 'maintenance free' but in reality you can back off the rocker retaining bolts and then go through the firing order, tightening each 1/4 turn past seated (or to 20ftlb) as that respective valve closes.
The carburettor will vary depending on model. For this you are best to reset to factory specs - Holley carbs are 3/4 turn out from seated for idle mixture screws and the idle set to 1/3 of the transfer slot showing under the throttle blade, plus your float height set to roughly 1/2 inch gap between float and top of bowl when removed and held upside down. I would recommend stock jet and power valve sizes if unfamiliar, otherwise simply renew the accelerator pump and power valve with known good units and replace what was originally there.
Ignition should be in the vicinity of 10 degrees before top dead center (BTDC) - again this will vary with engine and camshaft fitted. Some engines run best with lower timing, say 5 degrees BTDC, and other like more. See what yours likes.
Check your points gap if running a points distributor. Also check your spark plugs - a .040" gap is often recommended but if you have electronic ignition or hot coil set it for about .060" for a stronger spark.
Oil and filter change... and you're good to go.
Old Apr 15, 2017 | 12:06 AM
HIO Silver's Avatar
HIO Silver
With every tune up, I recommend hitting every grease fitting with new grease. All of them.
Every 4th oil change, repack the wheel bearings.
Nathan Plemons
21
Jun 21, 2009 07:38 PM
daveengelson
Jan 12, 2006 06:44 PM
67coupe351w
Feb 17, 2005 05:27 AM
Carbon88
Aug 20, 2004 09:55 PM
Sanders
Jun 6, 2004 12:16 AM
