Going rate headgasket replacement
I would normally walk away at that point but the rest of the truck is in great shape and the dealer seems mildly interested in negotiating in it's current shape. I would rather buy the truck "as is" and have it repaired myself then to have them do it.
I'm getting a couple of quotes and part lists from a few diesel shops so I can come up with a true value for the truck in it current shape to negotiate with.
The dealer claims the heads are in good shape. I'm still waiting on how they know as I don't think they pulled them. They may have pressure/leak tested them but I don't think that is a definitive test in if they are "good" or not.
Anyway assuming that they are correct and the heads just need decked and not replaced does the list of parts/labor etc below seem reasonable?
Ford 20mm head gaskets (2)- $312
ARP headstud kit - $450
STC updated fitting - $48
Standpipe and dummy plug kit - $112
Ford blue spring fuel regulator kit - $40
Ford injector o-ring kit (8) - $40
Exhaust manifold gasket (2)- $25
Manifold bolts (16) - $16
Turbo reinstall kit - $10
Turbo drain tube - $27
Filters (oil and fuel) - $52
Oil and coolant - $150
Misc supplies/parts - $100
Labor - $1800
Machine shop (magnaflux and deck heads) - $850 - not sure on the cost to do both heads
Total: $4032
Some other items I'm not sure of are:
Turbo updated feed line - I think the 2007 got this already?
Oil cooler - The current cooler seemed fine and deltas on test drive seemed good. I may do this anyway but I don't think it is "necessary"?
Other notes:
EGR delete - It may already have it done but if not I would do this myself anyway.
Coolant filter - It already had one from XDP.
This would be a good time to install fumoto block drains.
Probably wouldn't hurt to install a new oil cooler. Ford did an upgrade on it (one additional cooling row).
I would probably replace the heater hoses even though there aren't that many miles on the engine. Same with glow plugs and glow plug harnesses.
No return regulated fuel system? At least install a fuel pressure sensor and gauge. How about an exhaust gas temperature sensor and gauge also?
Oh - and how about re-sealing the injectors?
that being said, this was a shady used car lot. They did not have the heads machined, let alone test them for flatness. They would disassemble and then reassemble with cheap, unknown brand head gaskets and the ARP studs. I even got into an argument with one of the mechanics over it. He was saying studs were just as prone to failure as the OEM head bolts. The studs installed there were prone to failure, but it was due to improper preperation, cheap gaskets, and ignoring any and all warped heads. It was cheap though.
If i were to buy another 6.0 and it was time for studs, i wouldn't have a problem paying 4 grand to have it done right and not worry about it again.
Would there be much of an advantage to doing a regulated return if I'm mainly going to keep tuning stock?
You have a link to a reseal kit? I just found an o-ring kit.
If this where a gas engine I would probably do all the work myself (except the machining of course) but haven't been inside a 6.0 or a diesel for that matter.
Motorcraft 6.0L Injector O-rings 03-07 - Riffraff Diesel Performance
Also, I'd consider doing the nipple cups themselves if they are loose.
Oh well. I guess I'll keep looking. Thanks for all the input guys. It help me be informed and not over reach on price.
$1200-$2000 a head from Ford IIRC from a few threads...
There is a guy local(within 100 miles) that does a stud job for 3K all Ford parts, heads machined, valve job and milled with ARP studs. As long as your heads are not cracked he switches your heads out with one of 10 sets he keeps on hand.
5-10 day turn around time once you can get in the door. Usually a 2-6 week wait.
The other shop I use that is 25 miles away quoted 3-6k and a 3 week window.
YMMV from shop to shop!
