6inch lift question concern
Old Apr 13, 2017 | 07:38 PM
Chris Crews's Avatar
Chris Crews
So I was thinking about this going into work. Those of you who have a 6 inch lift.... are you still able to go through drive throughs at restaurants and places like that with the 7-8ft clearance bar hanging down???
im curious because if my math is right a 6 inch lift added to these trucks puts it at 7.5 inches of lift with the 1.5 stock included.
Old Apr 13, 2017 | 09:29 PM
eberlestock's Avatar
eberlestock
You definitely are more limited to where you can go with a lifted rig! Not sure what you mean about "1.5 stock included"? Does your truck already have a 1.5" lift block?
Old Apr 13, 2017 | 09:38 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
I've yet to be hindered by the lifts on the trucks. I worry more about sharp exits turns thru the drive thru Hitting my rims. 😄
Old Apr 13, 2017 | 11:57 PM
Chris Crews
I mean that I was under the impression from the factory these trucks already sit super high. Like someone said they have an inch and a half lift. So I'm saying if you have a 6inch lift that would give you a seven and a half inch lift so then I'm asking has anyone had any trouble clearing those bars that hang down in drive throughs.
And also yeah I know what you mean about the wheels but that's why I think getting a rim that fits the tire is a better idea. People who run 24x14 or bigger are asking for messed up wheels on curbs
Old Apr 14, 2017 | 12:13 AM
willynilly's Avatar
willynilly
i never made it through high school but from what i remember 6+0=6. how your getting 1.5 makes no sense to me
Old Apr 14, 2017 | 12:19 AM
MagicMtnDan's Avatar
MagicMtnDan
I did finish HS and I agree with you
The stock SD height is the height. Adding 6" lift makes it stock height + 6"
Old Apr 14, 2017 | 02:38 AM
Chris Crews
Okay.... uh.
https://youtu.be/-UXUGG3ZfAA
listen to what this guy says. I know I'm not crazy. He said with the trucks, from the factory they already sit pretty high. As if someone put at 1.5 inch lift on it. So this guy is saying adding a 4.5 inch lift will equal out to A true 6 inch lift factoring in the stock height.
So so if you take a 6 inch lift and factor in the factory stock height that comes out to 7.5 of lift.
Am am I crazy here?
Old Apr 14, 2017 | 05:12 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Yes
Kind of reminds me of guys saying 67-77.5 highboy trucks have a "fsctory lift"
Stock truck is stock, add a 4" lift thats 4"
Amd remember most lifts level the truck so the full lift amount is added to the front and the balance is only ususally added to the rear
Old Apr 14, 2017 | 09:24 AM
jimzpsd's Avatar
jimzpsd
To the OP, keep in mind if you lift your truck, then most likely wheels and tires will be next making your rig taller yet. Your end result will be dictated by the components you choose.
Old Apr 14, 2017 | 12:23 PM
Canadian Dozer's Avatar
Canadian Dozer
As said earlier don't' most of the lifts kits level the truck out 1st? A 4" lift raises the front end 4" and actually only lifts the back end 1 1/2". The truck then sits level but only 2" taller overall. You now have the option of running a 37" tire which gives you almost another 2". Between the tires and the lift you get your 4". So a 6" lift doesn't necessarily mean the truck sits 6" taller.
Old Apr 14, 2017 | 01:22 PM
fuelpro's Avatar
fuelpro
i have a 4.5" and its crazy tall
Old Apr 14, 2017 | 03:48 PM
Chris Crews
Do you find yourself straining to get into the 4.5 inch lifted truck?
im 6"2 so I don't have a hard time which is why I'm thinking the 6inch will be fine for me. I'm just concerned about clearing stuff in a drive through. Obviously I won't be able to park in a parking garage
Old Apr 14, 2017 | 04:19 PM
MagicMtnDan
Wait...here's the new math:
* Stock truck
* It's 2" taller = +2"
* 4" lift = +4"
* 37" tires = +2"
* Feels like 2" more = +2"
Total: 10"
Just kidding
Old Apr 14, 2017 | 04:44 PM
fuelpro's Avatar
fuelpro
its a climb for sure with the lift and tires but im closer to 5'10. All i was saying is its way taller than i ever imagined it would be.
Old Apr 14, 2017 | 04:46 PM
225nontypical's Avatar
225nontypical
I have had no issues with my truck (I dont use parking garages though). I have a 6" lift and 38" tires.
I think what the op was referring to is that the 17 superduty trucks sit roughly an inch and a half taller (stock) then the 16 super duty trucks did. I had a 4" lift and 37" tires on my 14 and my stock 17 was only roughly 2 1/2" inches shorter.
so if your were to compare overall height of a 16 vs 17 both having a 6" lift and the same tires the 17 would sit higher.
