What's this?"
Old Apr 12, 2017 | 09:39 PM
Chris Karsseboom's Avatar
Chris Karsseboom
What's this?"
Sits right under the steering column. Truck is an e99
Old Apr 12, 2017 | 11:19 PM
BBslider001's Avatar
BBslider001
Great question. I'd like to know myself.
Old Apr 13, 2017 | 08:18 AM
Walleye Hunter's Avatar
Walleye Hunter
I see part numbers on the face of it go to this site here and plug the part number into the search box in the upper right of their web page.
1999 Ford F-250 Super Duty
Old Apr 13, 2017 | 08:37 AM
Rikster-7700's Avatar
Rikster-7700
It almost looks like his OBD II plug?
Old Apr 13, 2017 | 09:21 AM
Chris Karsseboom
Great it's the baro sensor. The e99 had a stand alone sensor, where as the newer has the sensor built into the pcm. I'm in the process of swapping dash wire harness with a 2000 which doesn't have that plug? Will I now need a 2000 pcm to function?
Old Apr 13, 2017 | 10:38 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes.
​​​​​​​ Or you can simply just wire the Baro sensor into the 2000 harness. It's simple to do. I did it on my 2000 and 2002 pickups so that I can use an E99 PCM in them.
Old Apr 13, 2017 | 11:28 AM
Chris Karsseboom
Originally Posted by cleatus12r
Yes.
how do you wire it in?
Old Apr 13, 2017 | 11:36 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Simply splice into the 5 volt reference and Signal return line (ground) and then use the normal sensor wire that you already have in the under hood portion of the wiring harness that goes to the PCM. At this point, it would just be easier to locate the barometric pressure sensor under the hood.
Old Apr 13, 2017 | 09:02 PM
Chris Karsseboom
So I got the new dash harness and all seems to work but the gauges, dummies lights work but no temp, gas, battery, rpm, etc... this harness was from an auto and mines a standard transmission
So does the cluster gauges get their signal from the pcm or the gem module?
raxxter
Sep 9, 2018 07:23 PM
mrgoodwood
Sep 17, 2012 08:25 PM
1OldFordMan
Feb 14, 2010 08:00 AM
hivolt5.0
Feb 21, 2009 03:29 AM
65fordguy
Jul 24, 2008 12:52 PM
