1978 - 1996 Big Bronco
ABS Problem
Old Apr 11, 2017 | 05:47 AM
para's Avatar
para
ABS Problem
So I may buy a new 96 Bronco and it has issues. One of the issues that may make me buy it or not is that the ABS light is on.
If its a wheel sensor no problem, if its the ABS hydraulic computer, forget it. After what I went through with a Jeep I had forget it. Half of the used ones never work. I ended up buying an entrire car to get one that worked, not doing that again
Anyways, I had the idea of connecting an OBDII code reader and have it tell me. Prev owner says you can not do that and you need to connect to some different connector or harness, etc
Any ideas on how I can easily tell if its the module vs a wheel sensor?
Old Apr 11, 2017 | 08:43 PM
g_k50's Avatar
g_k50
buy the cheaper one, trade that part out and see if that changes anything, repeat as necessary.
Do the brakes work? Might want to consider some black electrical tape. You know, you put a piece of tape over the light and problem solved?
Old Apr 11, 2017 | 09:33 PM
amfmtxca1's Avatar
amfmtxca1
Is that tip in Haynes manual?
Jay Banks
Aug 2, 2011 07:44 PM
dogg16
Jun 25, 2010 06:33 AM
dennyo
Feb 11, 2009 09:49 AM
davenpt
1997 - 2003 F150
18
Sep 27, 2005 04:52 PM
ROKNZRX
Mar 23, 2005 07:25 PM
