2003 Excursion - Error P0231
Looking for some help or advice. I bought my Excursion about 3 months ago. So far I've replaced the Alt and battery all because it randomly die on me. I guess no the issue isnt the Alt or battery but an error P0231.
P0231 Low Voltage Fuel Pump Secondary Circuit
Read more at: https://www.obd-codes.com/p0231
Copyright OBD-Codes.com
I've replaced what I thought was the fuse but not 100 percent sure. I cleared the error message and now it's still doing the random turn off. Now I'm getting an error P1000. Has anyone ran into this issue before? Tried google search with very little success.
If so, I am chasing the same problem and posted it here https://www.ford-trucks.com/forums/1...lp-please.html
There are other threads, but people describe stalling conditions differently. I'll post up other boomarked threads in a while....but search out PCM issues, too.
The PCM issue is not a service bulletin according to the dealer.
There, saved you a $1K
I haven't seen any codes on mine though. It was the dealer who said they pulled a P0231 - I never saw it with my code reader.
I was told and somebody provided schematics that reflect the fuel pump relay is on the PCM, which is located in a separate box behind the stereo.
Dealer said the fuel pump relay is on the central junction fuse box, and that it was fine. But, I'm not confident they accurately tested either irrespective of where it is located.
Here is my original dealer ticket, and the PCM board location in our 2003 models:
