New steering wheel????
Old Apr 10, 2017 | 05:56 PM
greagin's Avatar
greagin
Anyone know what year steering wheels will fit my 2001 f250? Mine is worn slap out and I'm gonna have to get a new one, ford says discontinued for new stock, eBay doesn't have too much to choose from. Just curious as to what all years would be compatible
Old Apr 10, 2017 | 06:03 PM
Walleye Hunter's Avatar
Walleye Hunter
Tugly's got a sweet steering wheel, check with him.
Old Apr 10, 2017 | 06:21 PM
greagin's Avatar
greagin
Roger that
Old Apr 10, 2017 | 06:39 PM
Tugly's Avatar
Tugly
I went from the one who everybody chastised for my wheel, to the guy everybody points to when it comes wheel time. All it took was a sizable Buck$Zooka blast to change everybody's perspective - go figure.
Here's a [LINK] to where I got mine.
...aaaannnd here's the adventure: [LINK]
Old Apr 10, 2017 | 09:27 PM
F250_'s Avatar
F250_
Old Apr 10, 2017 | 09:46 PM
DieselDenny's Avatar
DieselDenny
Rich, your link sent us to everything but? What exactly did you replace it with?
Part # ?
E99 here, looking.
Denny
Old Apr 10, 2017 | 09:49 PM
DieselDenny
Pete, I'm on it. Thanx bud!!
Denny (I'll post when we getter!)
Old Apr 10, 2017 | 09:53 PM
DieselDenny
Rich, one link worked (upper, the other didn't.) For me anyway.
3 hundo isn't a bad deal. You like it, or just...........like it?
Denny
Old Apr 11, 2017 | 07:36 AM
F250_'s Avatar
F250_
The links I posted above were from a quickie search, and not from the search results I found last summer. The prices I saw then were in the $250-$350 range for restored (re-skinned) OEM steering wheels and they looked exactly like OEM in their fit and finish... I just can;t find where I kept those links because I ended up getting my steering wheel "clean enough" for the vehicle to sell without it being a sore thumb.
Deeper and more patient searching may find better results. Then, too, Rich's link is right within what I was seeing last summer, too.
Old Apr 11, 2017 | 10:12 AM
greagin's Avatar
greagin
Awesome info!!! Thank you all!!!
Old Apr 11, 2017 | 11:19 AM
ZachinCO's Avatar
ZachinCO
I found this thread, may be helpful.
https://www.ford-trucks.com/forums/9...eel-cover.html
Old Apr 11, 2017 | 11:47 AM
F250_'s Avatar
F250_
The company used by the OP in that older thread is one of the links I posted above (Dallas Custom Steering Wheel).
Old Apr 11, 2017 | 01:25 PM
timf150's Avatar
timf150
I found a Navigator steering wheel and repaired it. I sanded it down, primed it and painted it and here is the results.
All navigator wheels up to 2002 will work, all excursion steering wheels will work and Trucks from 99-07 should work.
Do you want a wheel with the additional buttons? I really love controlling my radio and Climate from the steering wheel.
Tim M
Old Apr 11, 2017 | 01:45 PM
ZachinCO's Avatar
ZachinCO
Tim M
I'm assuming you had to run that additional wiring to the head unit to control the extras?
Old Apr 11, 2017 | 02:24 PM
timf150's Avatar
timf150
I was lucky that my 2002 Ex had the wires already under the steering wheel and routed to the back of the stereo and climate control.
I have an aftermarket stereo so I had to add a device to allow steering wheel controls to manage the stereo and that can be wired directly.
Climate control can also be wired directly if the wire is not present. There is a thread out in the excursion forum that goes into detail about the different installs.
You will need a new clock spring to make the other control buttons work. I used the clock spring from the same navigator I got the steering wheel from.
Tim M
